Mirrors
Old Mar 15, 2005 | 11:27 PM
layd out's Avatar
o ya
Old Mar 16, 2005 | 12:14 AM
Does anyone have any idea what is the process to sand and smooth these mirrors out because I want to paint the black part and leave the chrome what kind of sand paper should I start with maybe 200 or 400 any suggestions or tips?
Old Mar 16, 2005 | 12:23 AM
JSmith's Avatar
Use 400 to knock down the texture and then follow that with some 800-1000 grit to finish it out. Don't go too heavy on the initial grit because once you get a deep scratch it's a pain to get rid of and sanding it away in one spot will leave a divit in the plastic.
Old Mar 16, 2005 | 11:57 AM
So I should start with 400 because I want to sand a little before I take them to the guy who is going to paint them do you think just using 400 grit would be enough?
Old Mar 16, 2005 | 12:34 PM
JSmith's Avatar
I would start at 400. The plastic that those mirrors are made of is pretty soft and scratches/gouges super easy from heavy grit sand paper. Hiding deep scratches/gouges in plastic doesn't work the same as it would with metal. If you're paint guy is going to do the final prep I would just knock down the texture with 400. If you want to do the smoothing yourself, I'd finish it off with some 800 or even 1000.
Old Mar 16, 2005 | 12:48 PM
03rado5.3's Avatar
the plugs on the 03's are different from the 99-02's, the cord is also alot longer, b/c I bought a set of the wrong streetscene mirrors and the cord was to short so I sold them to a friend, and finally ended up getting the right ones
Old Mar 16, 2005 | 02:03 PM
Here are some pics of one of my handles that I sanded and smoothed out well the first is of the textured handle and the other is of the smooth one I just dont want to mess up anything Its just that I have never done this before let me know what you think?
Old Mar 16, 2005 | 11:44 PM
JSmith's Avatar
From what I can see of the bottom pic, that looks good. All the texture is gone? If so, I'd say they're ready.
Old Mar 17, 2005 | 07:32 AM
Check out this pic I started to sand my mirror from the bottom what do you think is it normal to have thoe little lines?
Old Mar 17, 2005 | 04:43 PM
Someone?
