Lowering Kit
Ive got a 2004 Chevy Avalanche and im looking for a nice lowering kit. ive got 22's on it and its pretty high. i dont know if i should run a 2-3 or a 4-6. any suggestions on a kit and height?
first thing i guess is the wheel/tire specs your running...whats the offset on your rims? what size tires..this is a big factor, when thinking about the 4/6 drop especially
the rims are 22 inch, tires- 305 40R 22. i dont know the offset of the rims. where would i find that out?
if your unsure of the offset..another option is measuring the backspace of the rim..place a straightedge across the backside of the rim..lip to lip of rim, not tire buldge..and measure to the mounting surface..
Also..that tire size isnt 4/6 drop friendly at all..265/35 is the norm for 22's and that drop.. Best bet without any worries, in my opinion is aim for the 2/3 drop you mentioned..unless you want to get into buying new tires..and possibly rims. |
alright sounds to complicated. ill just stick with the 2/3 drop. but i am having to get new tires soon. i could always change to a lower profile tire if there is one...
I'm going 285/40/22 with 5.5" of BS...should I be fine with a 3/5 drop? Has anyone noticed more room in the wheel wells of the NNBS?
Go with a 3/5 drop it should work great with you
who makes the 3/5 drop?
front: 1" springs/2" spindles 4" control arms/1" coil spacer 3" springs 2" control arms/1" springs 3" control arms Rear: Flip kit with 1" lift shackle 4" leaf springs with 1" drop shackle 2" shackles/2" hangers with overload leaf removed(comes out to about 4.75") 3" leaf springs/ 2" shackle |
These are 22" wheels with 305/40 tires, with a 2/3 drop (spindle/coil)
The height should look about the same on your truck, I think its perfect for a daily driven vehicle. it can rub a bit, I think with 3/5 it would be even worse. Sorry I don't have any better pics, this doesn't really show how low it is. https://www.performancetrucks.net/fo...chmentid=42380 |
