leather armrest
Old Sep 22, 2007 | 09:34 PM
2000LT's Avatar
Default leather armrest
hey guys ive got a 2000 lt with charcol leather seats... anyway i can replace the driver arm rest? its cracked to ****
let me know thanks
even just a gm part number
Old Sep 22, 2007 | 10:21 PM
Superado's Avatar
11 Second Truck Club
same issue here...part # 88936774
part is $217.11 at the stealership!
and instructions for R&R...
Front Seat Armrest Replacement
Removal Procedure
Set the front seat back in the forward position.
Separate the J-clip at the bottom of the seat using a flat bladed tool.
Remove the 2 push pins at the bottom retaining the seat back cover to the card board.
From the back of the front seat, disconnect the heating element wire connector, if equipped.
Role up the seat cover up to the bottom of the arm rest.
Recline the seat.
From the front of the seat move the seat cushion away from the seat frame to gain access to the arm rest clip.
Remove the rubber band from the clip.
Remove the clip from the seat frame.
Remove the arm rest by pulling outwards.
Installation Procedure
Install the clip in the slot of the seat frame.
Install the rubber band on the clip to retain it in place.
Fold down the seat cover.
Install the arm rest by pressing in until it is fully seated.
Connect the heating element wire connector.
Pull down on the seat cover in order to install the 2 push pins retaining the seat back to the card board.
Connect the J-clip at the bottom of the seat.
Push on the seat back cover to ensure the cover is held in place by the velcro.
Old Sep 22, 2007 | 10:35 PM
2000LT's Avatar
holly hell!
Old Sep 22, 2007 | 10:37 PM
2000LT's Avatar
171 what a steal!
http://www.gmpartsdirect.com/results.cfm
cheyenne383
Nov 13, 2015 09:24 AM
turbo6c3
Oct 5, 2015 06:11 PM
97_ek
Sep 23, 2015 09:16 PM
2004gibbstruck
Sep 7, 2015 06:05 PM
