It's on!
Old Oct 7, 2006 | 08:35 PM
  #31
trever1t's Avatar
2nd fastest 5.3 ECSB
Now that i've shed the weight, the tail has come up an inch it seems. I got the front down with 2" drop spindles and about 1" torsion bar drop. I was thinking of taking the 1" back up on the torsions? It would probably ride a little better with torsion up 1/2-3/4" too.
What do you think?
Torsion up 3/4" or down rear 1"?
How would I drop the rear any more? Already have shackles and hangars.
I like a little go with my show!
Old Oct 7, 2006 | 11:52 PM
  #32
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Remove the Z71 lift blocks and use 2wd U bolts in the back.
Old Oct 8, 2006 | 12:06 AM
  #33
5.3AlmnBlk's Avatar
I remember when trever joined the site and he had a l33 so i was like ill see what works for him and it will work for me but your truck has come a long way performance and look wise, you did so much stuff to that truck that my money did not fallow and it looks great though i have a chevy and like them lifted but i like the sierras riding low!! Truck looks great keep it up!
Old Oct 8, 2006 | 12:17 AM
  #34
trever1t's Avatar
1Slow, last time i looked the blocks were like 2". Can i find a 1" block to replace them?
5.3AlmnBlk yeah, sorry. Money goes thru my hands quickly. Thanks!
Old Oct 8, 2006 | 12:22 AM
  #35
1slow01Z71's Avatar
Your shackles have two positions your bolt is currently in teh 2" drop position just move th ebolt up to the 1" drop position
Old Oct 8, 2006 | 10:45 AM
  #36
trever1t's Avatar
Couldn't get the bolt in that #1 position. Is there a 'trick' to getting it in there?
Old Oct 8, 2006 | 12:38 PM
  #37
1slow01Z71's Avatar
What is keeping you from sliding it in? Should just slip right in.
Old Oct 8, 2006 | 05:05 PM
  #38
moregrip's Avatar
what a rush!
truck is looking better all the time! lookin good brother!
Old Oct 8, 2006 | 08:37 PM
  #39
trever1t's Avatar
Frame blocks bolt Someone did a write up on it a while back. I might just twist the torsions a 1/2 inch and call it a day
Thanks Grippy!
Old Oct 8, 2006 | 08:53 PM
  #40
MorepowerTY's Avatar
There is a trick to the shackels Bill, its called a "BFH". No, I had to jack up my truck from under neith and let the leaf spring drop alittle. Then you can get that second hole. Its a tough one though. A little cursing and fighting with it, but it'll go. Your truck is look'n great dude.
