HID wire harness
Old Jul 8, 2006 | 07:43 AM
Default HID wire harness
Just a quick question for you guys with HID's how did you wire your HID harness did you as in where did you ground it and where and did you connect it directly to the battery.
Thanks
Old Jul 8, 2006 | 11:38 AM
99Silver6.0's Avatar
Dont really see why thats necessary. Of the 3 HID kits I had including my Xenarcs, stock harness was always utilized. With no negative effects. Never popped a fuse or a relay.
Old Jul 8, 2006 | 03:15 PM
really not even the Xenarcs I just got the Philips kit from Xenon Depot and you have to use the Harness
Old Jul 8, 2006 | 08:20 PM
8MC's Avatar
8MC
Can you post a wiring diagram or link to the kit you wound up buying ?
Old Jul 8, 2006 | 11:11 PM
I really do not see the need at all. But then again, some vehicles have shitty headlight wiring. But, explained fruther... HID ballasts do not consume anywhere NEAR the power that a normal halogen bulb uses! The only time that they need the power is upon bulb ignition and that is it. If you put any HID setup into your truck and you pop a fuse then YES you have issues. And the ballasts are sucking alot of amperage to ignite the bulb. That usually happens with, im gonna use the word again, SHITTY jap HID capsules. BUT, if you dont pop a fuse when the ballast hits, when the lights are turned on. Leave the wiring alone.
I have NEVER had a problem with any HID kit ive had in 5 years!!! No fuses, no wires, no relays. Nothing.
Old Jul 10, 2006 | 12:59 PM
Yeah but the HID kit I bought I need to connect the harness in order to run them but I will most definitely use it.
Texas5.3_1251
Mar 5, 2016 08:10 PM
SLOPONY
11
Sep 24, 2015 02:47 PM
Silver8ado
Sep 14, 2015 06:35 PM
spooneralmighty
Sep 11, 2015 02:28 PM
muncie21
Sep 7, 2015 09:55 PM
