help! screwed up paint on bowtie
Old May 14, 2006 | 06:59 PM
OrlandoFL4.8's Avatar
Default help! screwed up paint on bowtie
Today I decided to paint my bowtie as many others have done. I first sanded it down, put 3 coats of primer, sanded it again, put 4 coats of black, and then 2 coats of clear. Well when I went to put the 3rd coat of clear I grabbed the wrong can and put a light mist of primer on it before I said a few choice words. What do I do now, do I sand the tainted clear coat down and put more coats of black and clear again?
Old May 14, 2006 | 08:07 PM
TouchOfEvil04's Avatar
I would sand it again put one more coat of black then a coat or two of clear again...
Old May 14, 2006 | 08:50 PM
goshawk23's Avatar
Truck addict
do it again, no biggy. just time. that extra time and effort will show when it's done.
Old May 14, 2006 | 09:32 PM
04BlackSilverado's Avatar
Get some 1000 grit and wet sand it and do another layer or two of clear. You have two layers of clear under the "mist" so wet sanding should not take more than one layer.
No big deal if it is really fucked up, just sand it sown some and build it up again. I have painted mind like three times from highway rocks.
Old May 14, 2006 | 09:50 PM
Thanks everyone, I hit it with some 1000 grit and the mist dissappeared and actually smoothed it out a bit. I will hit it with 2 more coats of clear and should be ok
Old May 15, 2006 | 06:17 PM
kdirectorate's Avatar
I had a similar problem. I finished painting mine and clearing it and then discovered that the white was way off... I knocked it back down and started over again.
You're going to have to post a pic or two you know...
cheyenne383
Nov 13, 2015 09:24 AM
03sierraslt
14
Oct 9, 2015 05:53 AM
turbo6c3
Oct 5, 2015 06:11 PM
gmcyukon
Oct 3, 2015 11:03 PM
sprayed99
Sep 14, 2015 12:36 PM
