Help on installing LEDS
Old Jun 28, 2005 | 01:01 PM
foxracingfreak's Avatar
Default Help on installing LEDS
i have recently bought some small LEDS for my window switches radio, 4wd buttons and all the other intruments in my truck. i was wondering if anyone knows of any instructions on how to do this. thanks.
Old Jun 28, 2005 | 03:01 PM
solowsilverado's Avatar
I have done this mod & this site helped me:http://led.linear1.org/led.wiz
Desolder the bulbs & solder in the LED WITH resistor. Usually 470-560ohms on the resistor. I'd post pics, but for some reason, the system says it can't create a file for it.
Old Jun 28, 2005 | 06:15 PM
did you do everything?? even window switch?? what size leds did you use. i wish you could post pics so i can actually see what needs to be done. but thanks anyway..
Old Jun 30, 2005 | 02:55 PM
Haven't done the window, headlight, cargo light stuff yet. I am working on the window switches though. Here is a link to the AC panel with Blue LEDs:
http://img258.imageshack.us/my.php?i...cpanel29gk.jpg
I used 5mm 45 degree Blue ones from www.SuperBrightLEDS.com
I know the pic is a little blurry, but you get the idea. I did not just replace the 4 bulbs. I made a whole new setup. I'm working on the write-up now. I'll post that on GM Fullsize & FullSizeChevy when I get done. It will be under the same user name as I am on here.
Old Aug 7, 2005 | 09:28 AM
00z71white's Avatar
Default which bulbs?
ok so you used the 5mm bulbs for your AC panel. which bulbs did you buy for the door switches, 4wd and head light on/off switch? i have never soldered. is it hard to do this?
Old Aug 9, 2005 | 03:56 AM
Soldering has to be one of the easiest things in the world, and inexpensive to get materials for, lookin at around $30 for the gun and a 10' roll of solder.
Just have to make sure you get the polarity correct before u solder the led's, otherwise you gotta do it again, which isn't hard, just takes more time than needed.
Dave
Old Aug 10, 2005 | 08:53 PM
00z71white's Avatar
thanks but i actually figured out my buddy has everything and im sure we can do it. but i still dont know which size bulbs i need to order for each specific **** and button. anyone done it yet and could tell me which size bulbs go where?
carid
Jul 24, 2015 05:00 AM
Ketis
Jul 23, 2015 12:37 PM
HIDEXTRA
Jul 21, 2015 05:43 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
