Fogging clear corner ... !!! WTF
Old Dec 3, 2005 | 12:56 AM
YeLLow Fever's Avatar
Default Fogging clear corner ... !!! WTF
my Left clear corner keeps fogging after each time i wash my baby ... how can i stop such thing ... LOOOKS VERY disturbing .. HELP
Old Dec 3, 2005 | 01:10 AM
graystepside's Avatar
mine does the same thing. both my stock ones and my new clear corners fog.
Old Dec 3, 2005 | 01:16 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Mine dont do that most of the time every once in a while it will but then again its been like 4 months since I washed my truck so its kind of hard to remember. Most aftermarket clear corners have that problem. I got the cheap 20 buck ebay deals on my truck cant beat them for the price.
Old Dec 3, 2005 | 01:19 AM
If you just got em' I'd try taking them back.
My reflectors have been taken out of my headlights up front and when we put em' back together we used a lot of silicon. They haven't fell prey to condensation yet, knock on wood.
Once they clear up, you might be able to seal them a little better. Just a thought, don't know if it'll work.
Old Dec 3, 2005 | 07:35 AM
CoonToot's Avatar
I had the same problem on my cheapie eBay ones as well. Easy fix. When you wash the truck, water gets in but has no way to drain since they are still pretty much a closed environment. The water puddles and evaporates, but doesn't go anywhere so you get fogging.I took mine out and drilled 3 small holes at the lowest point of the assembly. Now water still gets in where it always has, but it has an escape route. No problems since. HTH.
Old Dec 3, 2005 | 07:39 AM
SSlow 4.8's Avatar
I ended up sealing up the edges where nessesary with clear silicon and than also putting holes in the bottom like coontoot said.
RustyD
May 23, 2016 07:04 PM
cheyenne383
Nov 13, 2015 09:24 AM
Alco
Oct 4, 2015 06:58 AM
KINGCYCLES
Oct 2, 2015 10:21 AM
Rockrz
Sep 29, 2015 09:07 AM
