Fogged up clear corners
Old Jan 14, 2004 | 04:46 PM
Question Fogged up clear corners
Can anybody tell me what causes clear corners to fog up and how to fix them so they don't? I bought a set about two weeks ago and one of them is fogging up now.
Old Jan 14, 2004 | 05:07 PM
sit n' low's Avatar
were the yellow markers in the corners taken out? they need to be pulled out, let the moisture dry up, them reseal the edges
Old Jan 14, 2004 | 06:27 PM
Nick99Chevy's Avatar
Condensation. Dry them out and run a bead of silicone around the edge.
Old Jan 14, 2004 | 06:38 PM
I know condensation is the end result, but didn't know why there were condensing. Wasn't sure if they were suppose to be sealed up or not. I had a guy tell me to drill a hole on the bottom to let in air so they wouldn't fog up. That didn't make much sense to me but figured I would post and see what some folks out there thought.
Old Jan 14, 2004 | 07:57 PM
That helps too.
Old Jan 15, 2004 | 01:19 AM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
The Denali projectors actually have a hole behind the reflector that goes to a rubber hose. The Sierra headlamps don't.
If your corner markers are getting condensed(I'm assuming they're clear corners since the same happened to mine, but not my stockers) get some wetsand paper and lightly sand them, that should take the yellow crap off. Then add some more silicone to seal em up well.
Old Jan 15, 2004 | 11:27 AM
KeukaZ71's Avatar
when i installed my PIAA's (foglights), they fogged up the 1st week. there was a hole in the back plate, but it was on top. so i removed the back plate and rotated it so the hole is toward the bottom. haven't seen any condensation yet
Old Jan 17, 2004 | 09:58 AM
indyjps's Avatar
had same prob with mine, i took them out and filled with water to find leak then i could seal it up. shake out as much of water as possible then blow dry with compressed air. i poured some rubbing alcohol in them to evaproate trace water that was left, make sure the air compressor has had condensation drained from tank recently or has a water seperator on it like you would use to paint with
Old Jan 18, 2004 | 02:03 PM
Brandon Boomhauer's Avatar
for the yellowing, you can use swirl mark remover, and Meguairs makes some clear plastic polish and cleaner. the polish works GREAT, makes them look good!
Old Jan 19, 2004 | 08:30 PM
Had the Same problem first time i waited to long and the water ate all the crome out of the light i did what Nick99 Said with the silicone Around the Seem and its never happend again and its been about a year or longer........
RustyD
May 23, 2016 07:04 PM
cheyenne383
Nov 13, 2015 09:24 AM
KINGCYCLES
Oct 2, 2015 10:21 AM
97_ek
Sep 23, 2015 09:16 PM
creekrat
Sep 10, 2015 12:59 AM
