Engine Bay Cleanin
Old Dec 15, 2006 | 03:07 PM
Yenkonoma's Avatar
Default Engine Bay Cleanin
Whats the best way to do this? I've got an '04 Sierra... i have acess to a really nice steam cleaner.... can i just turn that loose under the hood or are there precautions i should take? Thanks!
Old Dec 15, 2006 | 03:58 PM
Mangled03gmc's Avatar
Baltimore Whore
Yah just try not to hit any of the connections directly wit the steam or soap, ext ext, you should be fine
Old Dec 17, 2006 | 11:32 PM
1badsilver's Avatar
Spray simple green over the dry engine compartment, let sit about a minute, then rinse. That's what I do with most vehicles I detail and they come out great
Old Dec 18, 2006 | 09:05 AM
silver-mod-o's Avatar
Hunt&Fisherator
I use simple G it does a good job... I usually spray it on a warm (not hot) engine and let stand for about a minute and hose it off... high pressure works really well, just be careful of the alternator and coil packs and any other electrical you have out in the open.
Old Dec 18, 2006 | 11:36 AM
TXsilverado's Avatar
dont use simple green. my dad put it on his motor and it chewed up and stained the alt and various other parts under his hood. i use foaming motor cleaner (foaming carb cleaner) then a can of normal carb cleaner for the extra gunky stuff pressurized water...then dry it off by driving it around and hose it down with mcguires foaming tire shine and wipe it all down. it aughta look factory clean after that. i used that process on my new motor last night and it looks even better than my old 5.3
Old Dec 18, 2006 | 11:48 AM
Hunt&Fisherator
hhmmmm, I've never had a problem with SG... as a matter of fact I used it last night and it worked fine... I dunno.... I do want to try something new though, this does a good job but if I can find something that works better, I'm all for it.
Old Dec 18, 2006 | 04:57 PM
tarinitup's Avatar
9 Second Truck Club
I use a can of engine brite, powerwash it at the carwash, and then spray it with armour all after I drive it home and it is dry and hot.
Old Dec 18, 2006 | 07:58 PM
Phantom's Avatar
11 Second Club
I just use the tire and engine clean button at the car wash and it works pretty good.
Old Dec 18, 2006 | 08:26 PM
RoosterMcCandles's Avatar
Windex and a cloth diaper...
Old Dec 28, 2006 | 12:10 PM
adam1803's Avatar
You can use Simple green but DO NOT let it dry, it is corrosive but if you rinse it off really well it shouldn't cause any problems.
