electronic flasher for our trucks?
Old Jan 26, 2008 | 06:41 PM
2001CamaroGuy's Avatar
Default electronic flasher for our trucks?
I have swapped all my lights to LEDs (front and rear) and I'm having issue with the turn signals (standard "they blink way too fast" issue). I would just use a no -load flasher but the problem I see is that the new trucks don't use a "standard old flasher". Its a big, 10 pin, flasher unit and I have no clue where to come up with something to replace it with. I had thought about getting another unit, trying to remove the mechanical "flasher unit" part, and solder a connector to work with a standard no-load but I'm not sure if that will even work.
Anyone have an idea? I really don't want to go soldering load resistors all over the truck and would love to get rid of the "click click click" at the same time.
Old Jan 27, 2008 | 10:41 AM
ttt.....
Old Jan 27, 2008 | 10:38 PM
riddick1224's Avatar
Go to either -
www.superbrightleds.com
www.autolumination.com
They have everything you would need to do anything with lights. I just ordered all blue LED lights for the interior of my truck. They also sell the relays for the flashers so they won't go super fast.
Old Jan 28, 2008 | 12:00 AM
thanks, but that still leaves me in the same "place".....load resistors.....
as I said I'm trying to figure out how to actually swap the factory flasher (it isn't the "standard" old 3 pin/can type)....why GM had to change from the 50+ year old design turn signal system that worked perfectly, I have no clue....
Old Jan 28, 2008 | 03:04 PM
If you switch out the relays in the fuse box under the hood with the ones from the websites you shouldn't need any load resistors.
http://autolumination.com/equalizers.htm
Old Jan 28, 2008 | 03:14 PM
??? I'm lost? what relays form the website? all I see are flashers?
edit: just looked under the hood...there is no relay for the turns.....?
Old Jan 28, 2008 | 03:27 PM
I'm sorry those are the flashers. But with those plugged in you should not need the load resistors.
wrb002
Aug 31, 2015 12:00 PM
04BlackGmc
Jul 16, 2015 04:10 PM
black6spdz
Jul 16, 2015 01:32 AM
lxcoupe
Jul 15, 2015 10:03 PM
slowlsx
Jul 13, 2015 04:18 AM
