Detailed Aaron's(53Russell) truck
Old Aug 30, 2009 | 01:21 AM
95 bright teal's Avatar
Originally Posted by Perezownzu
nice good job i have heard some good things about the 105 and 205.
I have used them alot and I really like it, very versatile depending on pads,pressure, and time.
Originally Posted by BlackLM7
Big difference, for sure! You do great work. Tell us more about the Optimum "no rinse" car wash. It sucks living at an apartment complex that has no area to hand wash your car. Going to the coin-op places are getting old, especially since I only use the rinse option there, lol.
Optimum No Rinse is great, i have been using it on most of my details and about once a month on my truck.
You mix two cap fulls of the liquid with about 3-4 gallons of water. I usually use a sponge, and you wipe it on, flip the sponge and wipe it off. then dry it. Ill see if i can find a in depth right up. you dont have to hose the car down or anything.
I have the 32oz bottle that i bought in December and its still more than half full. you can also mix it up for a quick detailer or clay lubricant
Old Aug 31, 2009 | 01:40 AM
Here is the Ultimate ONR(optimum no rinse) thread from autopia
Originally Posted by integritydetail
ONR Dilutions (Per Label):
Wash solution: 1oz per 2 gallons
Clay lube: 2oz per gallon
Quick detailer: 8oz per gallon (updated from 6oz on earlier version)
ONR Directions (Per Label):
1. Add 1oz to 2 gallons of water in a wash bucket
2. Soak wash media in solution and wash vehicle in sections
3. Dry each section two clean towels consecutively
Alternate Method w/Presoak (Thanks SUPERBEE364 and EXCELDETAIL)
1. Spray down each panel with QD strength ONR. (pump type garden sprayer)
2. Wipe each panel down gently with a dripping wet MF from the ONR bucket.
3. Rinse and squeeze out the MF, get it dripping wet again, and redo the same panel.
4. Dry the panel with a clean MF followed by a second MF
(Sup prefers to use distilled water exclusively, too.)
No Rinse Guide With Pics by:Excel Detail
FAQs (Thanks Dr. G, BENCE & ANTHONY O.):
1. Why does it feel slimy and not foam?: ONR should feel somewhat slimy, as this provides lubrication/encapsulation which carries away the unwanted dirt particles from the surface. This is a good slime.
2. Why is my wash media so much dirtier than when I do a traditional wash?: ONR binds the dirt to the wash media intentionally. You should change mitts as needed. They can then be soaked in regular detergent to release the dirt before rinsing or washed in the machine.
3. What are the environmental advantages?: Much less water is used by eliminating the rinsing step, not to mention on average only 2 gallons are used to wash vs. 6-10 gallons with the two bucket method (not including rinsing). Also, with a regular wash the mitt will release the dirt into the (usually 5 gallon X 2) rinse bucket, it would likely end in the storm drains when you dumped the buckets. With the ONR wash you can wash your mitts in your machine and dump the remainder of the 2 gallons of solution into the sink or toilet where the dirt goes to the right place where water can be treated/purified. Optimum Products also come packaged in HDPE bottles (which are one of the few widely recyclable plastics)
4. Should I still use the two-bucket method to prevent marring?: ONR softens water, so the bigger particles just sink to the bottom of the bucket. It’s like having a built-in grit guard in the wash solution. Smaller particles end up in the wash media.
5. Is there any advantage to using DI/distilled water to make the solution?: Softer water cooperates well with ONR. ONR's actives bond to the minerals of hard waters, therefore you may add more ONR to harder waters. DI/distilled water have no such minerals and the cleaning/protecting power of ONR can be exploited without weakening. These kind of waters will feel slimier than tap water.
6. My ONR Clay lube lost its color, will it still do the job or is it ruined?: ONR may lose its color when the sun hits it directly, but this won't affect its performance.
7. My car is really dirty, should I use more of the concentrate?: Using significantly more than the recommended dosage won't multiply ONR's performance; it will work effectively with the recommended amounts. You can still fine-tune the dosage to your exact needs (soiling of the vehicle, water hardness, wash media type, etc.).
(1 oz per gallon vs 1 oz per 2 gallons)
Thank you for bringing up this question. The polymers in No Rinse have reactive groups that bond and trap dirt particles making the dirt particles virtually non-abrasive. They also bond to oily particles and emulsify them into water. The latter is equivalent to the cleaning action from soaps which also work by emulsifying oil particles into water. However, with soap there is no interaction with dirt. This is why adding No Rinse to a regular wash also helps protect the paint from dirt particles.
The No Rinse polymers also bond to all automotive surfaces and create a slick surface and act as a barrier to protect paint from marring. That is something that soap will not provide since surfactants in soaps have no affinity for painted or other automotive surfaces.
When you use 1 oz. of No Rinse in 1 or 2 gallons of water for your wash at the molecular level this provides hundreds of billions of polymer molecules to do what was said above. Additional product will not be necessary except if you are using tap water that contains high levels of minerals such as calcium hydroxide or silicates. In these cases some of the polymers will bond to these minerals and take them out of solution therefore more product might be necessary to compensate for this effect. This is another reason why adding No Rinse to a regular car wash soap improves the results when using tap water.
For claying, the recommended level is 2 oz. per gallon, however, the actual product usage is far less. For instance if you are using 16 oz. of clay lube to clay a car, at this dilution you are actually putting 1/4 oz. of No Rinse on the surface. Same thing goes for using No Rinse as a quick detailer.
These levels were of course tested for several months and hundreds of washes of heavily soiled cars before we started offering No Rinse three years ago. I hope this helps answer your question. Please let me know if I can be of further assistance. Thanks again.
Dr. G (copied from Optimum Forums Ask Dr. G section)
8. Can ONR be used to clean windows and interiors? Yes, ONR can be used for an interior and exterior glass cleaner. It can be used at the regular QD mix.....a bit stronger if you're doing nasty windows and a bit less if doing more regular upkeep type cars.
If you notice streaks and smears then you need to cut it back with water.
ONR Technique (Thanks SCOTTWAX):
Body: YouTube - Washing a Cayenne with ONR
Wheels: YouTube - Optimum No Rinse and wheels part 1
YouTube - Optimum No Rinse and wheels part 2
Engine: http://www.autopia.org/forum/car-det...ne-detail.html
Claying: YouTube - Claying with Optimum No Rinse
Touch-ups: YouTube - ONR vs bird bomb
Fenderwells:YouTube - Fenderwell cleaning with Optimum No Rinse Wash
ONR Wash Media Threads:
http://www.autopia.org/forum/car-det...o-you-use.html
http://www.autopia.org/forum/car-det...-onr-mitt.html
http://www.autopia.org/forum/car-det...onr-media.html
ONR Capabilities Threads:
http://www.autopia.org/forum/click-b...ed-limits.html
http://www.autopia.org/forum/click-b...nr-thread.html
http://www.autopia.org/forum/car-det...silverado.html
http://www.autopia.org/forum/car-det...-onr-pics.html
http://www.autopia.org/forum/click-b...-onr-time.html
http://www.autopia.org/forum/car-det...-stunning.html
http://www.autopia.org/forum/car-det...imony-onr.html
http://www.autopia.org/forum/car-det...cs-inside.html
Old Aug 31, 2009 | 11:16 PM
00Silv4.8's Avatar
dam man that thing was a filthy little piggy! lets do the body work on my truck then you can wash and wax to your hearts desire? Me love you long time?? haha (I keed I keed, I pay)
Old Aug 31, 2009 | 11:25 PM
lol
let me know when your ready, i just did a pewter bed cover for 2001camaroguy that looked just like your hood, but came out looking like a mirror.
Old Sep 1, 2009 | 02:19 AM
00Silv4.8's Avatar
dam I want u to do my hood now then haha
kyle's v
Oct 4, 2015 12:37 PM
wrb002
Aug 31, 2015 12:00 PM
Slammed96
Jul 27, 2015 07:22 AM
black6spdz
Jul 16, 2015 01:32 AM
