Denali headlights?
Old Apr 12, 2004 | 12:37 AM
Default Denali headlights?
Im thiking about getting either the denali headlights but not sure because I also want to get the HID light for my truck but getting both would be a bit pricey. So what do yall think?
Old Apr 12, 2004 | 03:50 AM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
I wouldn't put an HID kit in the stock headlamps because it won't be like the BMW and Mercedes. You will have major glare and the light will spread everywhere, I've seen it myself.
Having HIDs is 50% of it, the other 50% is the housing. There put together is what gives you that awesome HID look.
The Denali projectors are the perfect candidate for an HID set up on the GMC trucks, Chevy trucks have the option of getting the Xenarcs, which for about $500 you get the HID bulbs, ballasts and reflector headlamp. They're on my sister's Silvy and they look awesome.
Old Apr 13, 2004 | 10:50 PM
tranzfourmd's Avatar
Talking ditto that!
ditto to the gospel of chingon!
Old Apr 14, 2004 | 09:59 PM
Default Headlight swap
Does anyone know if the wiring is different for the Denali headlights than the regular Sierra because I know that that the Denali headlights use 9005 size bulbs.... And I wanted to know if the only thing different is the wiring..
Old Apr 14, 2004 | 10:59 PM
CHAGO's Avatar
plug and play dood, no worries about the wiring, you'll see how they hook up if you get them.
Old Apr 21, 2004 | 03:10 PM
skylerlt's Avatar
all you have to do is wire in the plug for the 9005 bulbs. the denali headlights use high beam bulbs for both high and low beams so you just have to switch the plug. i bought the plugs for mine at autozone but i think most places will have them.
Old Apr 23, 2004 | 10:02 AM
What is the bes place to buy some Denali Projectors? Or or those aftermarket any good?
Old Apr 23, 2004 | 11:37 AM
2001si3rr@'s Avatar
Were are you located in Texas? I have a set I might part with, if you are interested?
Old Apr 25, 2004 | 01:11 PM
Default Pics of your denali Headlights
Do you all have pics of your denali headlights? Because I just ordered some and I want to know what to expect and if is not any trouble do you all have night pics?
Thanks
Old Apr 25, 2004 | 01:24 PM
Here's the cut off line at night.
Here's a pic I found of them with HIDs in it. Cool huh?
