Declad Chevy 5 Spoke with Center Cap
Old Oct 4, 2017 | 05:16 PM
malibudave's Avatar
Default Declad Chevy 5 Spoke with Center Cap
Started to declad four 5 spoke, 20x8.5 Chevy Silverado Chrome Clad wheels.
After I removed the plastic center cap and plastic chrome cladding, I measured the inside diameter of the hub and found that is had a 7" ID.
I researched and found that Chevy Rally Caps, that originally came on C3 Corvettes, had a 7" outside diameter mounting ring where it clipped onto a Corvette rally wheel.
I bought a cheap Rally Police center caps on eBay. It was too tight to work with the inside diameter of the decladded wheel hub.
The rally center cap mounting "ring" is a solid piece and does not give when you try and install it onto the declad wheel.
With a band saw, I decided to pie cut the mounting ring of the center cap into 8 separate sections so it would give a little and allow the center cap to pressed onto the declad wheel hub.
After the eight pie cuts, it took a little pressure to mount the center cap onto the declad 5 spoke wheel, but it was easily removed with a screw driver (not recommended as it may scratch the wheel, but I was careful).
Below is the outcome.
There are other center caps you can use besides the one above. I chose the police rally cap because it was a lower profile and would not protrude past the lip of the wheel.
Here are a few options for center caps.
Old Oct 4, 2017 | 09:41 PM
skolman91's Avatar
Ugly as ****, but A for effort and thinking outside the box..
Old Oct 5, 2017 | 05:37 AM
malibudave's Avatar
Thanks.
Old Oct 5, 2017 | 01:12 PM
someotherguy's Avatar
ooof......
Old Oct 5, 2017 | 07:10 PM
stylinfosho's Avatar
I don't think they look bad at all similar to a 96 Impala SS wheel......
Old Oct 5, 2017 | 09:35 PM
skolman91's Avatar
so your truck gets flooded and im the ******* because of pointing out your bad wheel choices..
Got it
Id have to agree tho they look great in that pic since you cant see them..
