dash board paint
Old Feb 17, 2006 | 02:10 AM
03lowriderss's Avatar
Default dash board paint
who has painted a 99-current dash, what is the prep steps, it has a wierd rubber-ish texture on em stock.
Old Feb 17, 2006 | 04:58 AM
silver-mod-o's Avatar
Hunt&Fisherator
send a PM to foglemotorsports... I am sure He can give you some tips. he does great paint work on plastics.
Old Feb 17, 2006 | 06:31 AM
SBChvy's Avatar
03lowriderss-if you find out any information could you please post it. My dash is in need of some as well. Thank you.
Old Feb 17, 2006 | 06:48 AM
Hunt&Fisherator
well, in a nutshell... you have to sand it down smooth, use some primer and adhesion to get a good base. start off rough with the paper and work your way smoother. once you have it as smooth as you want it then put your basecoat down. (probably 2 coats and wetsand... and then do your clear... after your clear is set up then polish.
-I am sure I missed a step of two but it should give you an idea.
Old Feb 17, 2006 | 07:13 AM
Fogle07's Avatar
1. sand down till smooth with 180
2. prime the dash with high build primer
3. sand the primer down with 320-400
4. put one more coat of primer down to cover the 32-400 sand scratches
5. wetsand with 1000 till smooth
6. put down 2-3 coats of base
7. 2 coats of clear if your not going to cut and buff. 3 coats if you are.
Old Feb 17, 2006 | 08:30 AM
Hunt&Fisherator
-there you have it from the guru... LOL...
cheyenne383
Nov 13, 2015 09:24 AM
turbo6c3
Oct 5, 2015 06:11 PM
someotherguy
Oct 5, 2015 12:49 PM
gmcyukon
Oct 3, 2015 11:03 PM
the owl
Sep 4, 2015 04:09 PM
