Is this a correct comparison of Hotchkins and DJM?
Old Mar 1, 2004 | 07:41 PM
agreif's Avatar
Default Is this a correct comparison of Hotchkins and DJM?
I'm considering the 2/4 drop vs the 2" rear shackle and have read through almost all the threads on the 2/4 drops. I just want to make sure I have this right before I go thinking about it further. Thanks guys.
Brand
- How they get the drop
- Ride quality
- Handling
- Load capability
- Traction effects (wheel hop etc)
- Disadvantages
Hotchkins
- coil springs in front and new leafs in the back
- Ride is a stiffer
- Market advantage over stock handling (increase more with sways)
- Retains more load capacity and bottoms less than than most other kits
- Less weight transfer so less wheel hop
- Read that they tend to settle out and therefore bottom more as time goes on.
DJM
- Lower control arms in front and drop hangers/shackles in the back
- Similar to stock ride, doesn't beat you up as much as Hotch
- Better than stock (??) but not as good as Hotch
- I assume it doesn't change load as you have the same leafs...bottoming issues?
Mcgaughy's
- Drop spindles in front, rear??
Old Mar 2, 2004 | 03:11 AM
OUT2WIN's Avatar
you got it all under control, deciding which one to get is the hard part!
Old Mar 2, 2004 | 06:47 AM
Flem's Avatar
have you thought about the Mcgaughy's they have a drop spindle setup.the burbs have coils in the reAR but I'm going to do a 2/3 from them when the weather gets nice.
Old Mar 2, 2004 | 12:53 PM
BigKID's Avatar
I have two comments on you take of the Hotchkis setup:
- Although they advertise stock load capacity, you cant load up the bed as you can in a stock truck without bottoming out. 700-800 lbs is about all you can do.
- The stiffness of the leafs dosnt allow the weight transfer of a softer suspension but you should have no axle wrap (wheel hop) with the hotchkis leafs unless youare running a LOT of power. I have yet to have a caseof wheel hop on my truck since installing the hotchkis leafs.
Old Mar 2, 2004 | 01:00 PM
Does anyone have any experience with Ground Force products and how they compare to the above?
Old Mar 2, 2004 | 05:33 PM
agreif's Avatar
Flem, can you go into it any more?
Old Mar 10, 2004 | 04:23 PM
KJ
Lightbulb
Use Eibach! it rides alot better!!! They have a 2/3 drop contact me when you get ready & I will give you a good deal! (kjones@sdpc2000.com)
SloSVO
Nov 22, 2020 07:34 PM
madmann26
Apr 29, 2020 09:17 AM
Gadgetized
Oct 22, 2015 09:06 AM
JordanH
Oct 3, 2015 03:59 PM
vmaxpro
Sep 28, 2015 11:10 AM
