Console help?
Old Aug 15, 2006 | 03:49 PM
SaintLos's Avatar
Default Console help?
Just got a new jump seat/console for my 40/20/40 bench to replace the well worn one that broke last week.
None of the 3 bolts that mount it to the lower half of the seat will fit, am I missing something? Should I be re-drilling these mounting holes?
Help.
Old Aug 15, 2006 | 05:47 PM
moes04silverado's Avatar
they should just sit in the same bolt holes as the front inside part of the seats...i just took mine out so i feel that this is what you are talking about
Old Aug 16, 2006 | 07:52 AM
SaintLos's Avatar
They do sit in the same bolt holes. But the replacement console from the dealership lacks threads within those holes (original console has threads), so the original bolts wont screw in.
Old Aug 16, 2006 | 09:32 AM
interesting......
Old Aug 16, 2006 | 10:08 AM
thunder550's Avatar
High on diesel fumes
The console shouldn't have any threads......
I can't remember which is which for sure, but I think the front has threaded studs that come out of the floor, you put a nut on and tighten it down, and the rear has threaded holes in the floor that you put a bolt into. No threads on the console.
Old Aug 16, 2006 | 01:12 PM
i agree with thunder.....and be sure you put the console brackets under the seat brackets!!!
Old Aug 16, 2006 | 09:53 PM
budhayes3's Avatar
PT's Slowest Truck
Yea, I remember having to remove my seats to access the jump seat...I thought there were studs with nuts if I remember correctly...
Old Aug 16, 2006 | 10:35 PM
SaintLos's Avatar
Okay gang,
found the solution. First of all, I'm not replacing the entire jump seat. I am only replacing the seat back/console part.
The issue is that the dealer-ordered replacement is a 2006 style that uses self tapping screws as opposed to the original console that was pre-threaded for regular bolts.
Go5.3tt06
May 15, 2016 12:15 PM
nickpc82
Nov 2, 2015 02:49 PM
J.costello
Sep 25, 2015 05:31 PM
BKnBLK05
Aug 16, 2015 09:11 PM
My72olds
Jul 10, 2015 08:29 AM
