Changing out Grille
Old Apr 24, 2005 | 11:38 AM
Gunner's Avatar
Default Changing out Grille
Guys I am going to replace my front grille with a painted SS one. Is it tough? Do I need anyhting special to change it out?
Old Apr 24, 2005 | 12:10 PM
budhayes3's Avatar
PT's Slowest Truck
On my 99, removing the grille is a piece of cake. Use a flat blade screwdriver and/or door panel tool to remove the clips for the upper radiator cover and remove the cover. There's one 10mm bolt top dead center of the grille, and 4 clips (one in each corner) that require about a 1/4 turn counter clockwise with a phillips head screwdriver. After that the grille pretty much pops off. The corners (between the head and parking lights) are secured with clips. A little tug will pop em out.
Old Apr 24, 2005 | 03:12 PM
niwtsol's Avatar
that is how i took out my grille on my 04. how much was the ss grille?
Old Apr 24, 2005 | 05:30 PM
goshawk23's Avatar
Truck addict
it's a pretty easy process to getting the grill off. just do what was posted up above
Old Apr 24, 2005 | 06:21 PM
04BlackSilverado's Avatar
What year truck do you have? I'm assuming that its a 03-05.
What price are you expecting to pay for the SS grille? I'm look for a black one for my 04 and most have been around $300
Old Apr 25, 2005 | 06:40 AM
Gunner's Avatar
gm parts direct has it for like 275, not to bad. Sounds like I'll go for it.
6LITEREATER
Mar 4, 2026 06:13 AM
Deuce
Oct 30, 2015 08:25 PM
wrb002
Aug 25, 2015 03:56 PM
85SS/85GN
Aug 7, 2015 04:30 PM
carid
Jul 24, 2015 05:00 AM
