Candied tails!! PICs inside.....
Old Dec 10, 2006 | 04:42 PM
02BlueStepside's Avatar
Looks good! Can't see the imperfections in the pics. Try hitting them with some polish you would use on the paint of a vehicle, and then waxing them.
Old Dec 10, 2006 | 06:06 PM
COLDZ71's Avatar
I tried some Meguires polish and then some Carnuba wax. That didnt seem to work as good as Mothers Plastic Polish. Although I used that after the first two.
Old Dec 10, 2006 | 07:59 PM
budhayes3's Avatar
PT's Slowest Truck
Good job man, they look great!
Old Dec 12, 2006 | 04:36 PM
COLDZ71's Avatar
Thanks!!! The kind words are greatly appreciated.
Old Dec 12, 2006 | 10:43 PM
JT-bo's Avatar
I like that. would you be able to put a smoked layer over those candied layers?
Old Dec 13, 2006 | 05:31 AM
COLDZ71's Avatar
If you wanted to have the smoke look just use VHT Nightshades instead of the translucent red. The VHT will cover everything up fine, you wouldnt have to do a layer of red.
Old Dec 13, 2006 | 05:37 AM
beastmode's Avatar
Import Moderator
sorry to change the subject but does the light still get through that nightshade pretty good, i know its illegal to be paintin your tails and ive seen some sets that its illegal for a good reason... jwin how good it gets through the paint?
Old Dec 13, 2006 | 05:07 PM
JT-bo's Avatar
well I've got the gmc tails and I wouldn't want any yellow showing through
Old Dec 13, 2006 | 10:01 PM
COLDZ71's Avatar
Four coats of red covered the yellow so you couldnt even tell it was ever there. If you did the same with the Nightshades you wouldnt be able to tell there was yellow under it. You can use either red or smoke, one will be red, one will look black. They both cover really well.
Old Dec 14, 2006 | 06:33 PM
JT-bo's Avatar
thanks for the info. now I got build up the ***** to do it. I don't want to screw them up. my luck I would **** it up so bad I would need to by new lights.
