Can Anyone on here do this...
Old Feb 1, 2007 | 09:35 AM
CarmineSHOW's Avatar
Default Can Anyone on here do this...
is there ANYONE in the houston/woodlands/baytown/conroe anywhere inside this area..
That can remove all my molding the right way for a good price? Does anybody know neone that can do it for less than 200?
ANY info please guys!
Old Feb 1, 2007 | 11:05 AM
Siiverado44's Avatar
Man don't pay for something you can do yourself in about 10 minutes. Wait till June/July to do it, leave your truck sitting out in the sun for a few hours, and that molding will come right off. If you don't want to do that, get a heat gun and heat it up before you try it. I'd recommend a can of 3m adhesive remover. Just pull up the edge, spray, and pull.
Beware, if the molding has been on there a long time, (your truck is an 03) it may pull off the clearcoat or otherwise scar the paint when it comes off. It did on mine even, but its hardly noticeable on a dark truck.
Old Feb 1, 2007 | 11:53 AM
TXsilverado's Avatar
ill do it for 100
Old Feb 1, 2007 | 11:54 AM
riddick1224's Avatar
I got mine done at Buckalew Chevorlet in Conroe. I had them take off the door molding and the "Silverado"and "Chevorlet" and the "LS" tags too. They did it all for $60. It took him about 45 minutes.
Old Feb 1, 2007 | 12:03 PM
get a heat gun and heat up a corner. stick your fingers under there and pull it up. slowly peel the molding off with the heat gun aimed at the 3m goop, or do like i do and just tear that crap off once you get a corner off.
rub off the goop with gasoline...polish, wax, wax done
Old Feb 1, 2007 | 12:24 PM
blk_blazer00's Avatar
dont rub to hard w/ gasoline or your paint will come off..........that would be bad
Old Feb 1, 2007 | 12:26 PM
no it wont itll strip the wax off then hit the clear. thats why we polish and wax the area afterwords to replace the wax that gets stripped. i think chago used paint thinner one time without problems
Old Feb 1, 2007 | 12:31 PM
silver-mod-o's Avatar
Hunt&Fisherator
holy ****... crazy man right there...
Old Feb 1, 2007 | 02:32 PM
stone150's Avatar
i'll help you out for free, but youll do some work. called adhesive remover, pliers and a light touch with the eraser wheel. did it on mine and my buddie's truck
Old Feb 5, 2007 | 01:38 AM
Its done Thanks for all your help guys!
