can anyone help!!!!
Old Sep 12, 2003 | 09:29 AM
Default can anyone help!!!!
I installed my 10" kicker comps yesterday and they where hitting hard but that same day i changed them from one box to another and now they dont thump that good now the voice can be heard from the subwoofers WTF i didnt hear the voice when i first installed them on the first box but when i changed them to another box the voice started to hear i only got the amp connected no crossover or anything.......what should i do to take the voice of the subwoofers....
Old Sep 12, 2003 | 09:49 AM
RChevy4.8's Avatar
Default Re: can anyone help!!!!
You need the crossover to cut out the higher frequencies. The crossover cuts out the voices and only outputs the low bass. Check your amp and see if it has a crossover, and set it low. If not get a crossover or a new amp with a crossover.
Old Sep 12, 2003 | 06:31 PM
FILE's Avatar
So let me get this striaght. You had your system and the hitting hard and all you changed was boxes and now you have less bass and higher frequencies are filtered to you subs. I don't see how higher frequencies are being filtered to your subs if you are using the same amp and I imagine the same settings. Unless you had a ported box before and now a sealed box this can be possible. You see ported boxes are tuned to a certain low frequency. This is probably why the voices was not heard in your 1st box. Furthermore, a ported box will always give you more output than a sealed with the same power. I suggest just stay with the 1st box and if you can't keep it, adjust your LP crossover to you preferences if you are going with the 2nd box. HOpe this helps.
Old Sep 12, 2003 | 08:35 PM
1HOT99SILVERALDO's Avatar
Did the boxes you took out have anything on the inside of the box that the wire ran through?They make something you can hook up outside or inside the box to take the high's out,or they used to.
Mike
www.geocities.com/mikestruckshop2003/1HOT99SILVERADO
Old Sep 12, 2003 | 09:18 PM
My amp has a switch on it for 3 settings... you probably pushed it to the least bass/most high pitched setting. I have accidentally hit mine before and that has always been the case. Should just be a little sliding selector on the side of the amp.
Old Sep 14, 2003 | 01:39 AM
thats what happend bro but i got all fixed out now with all of your post thanks guyz
