? Bringing back far gone Aluminum
Old Dec 3, 2013 | 05:05 PM
Mangled03gmc's Avatar
Baltimore Whore
Yep a tumbler would be ideal. Roger, Tim are correct. A hard clean with a acid, followed by some elbow grease. Wet sanding starting with the lightest grit possible that still will cut the pitts away, once they are smooth you will need to use a finer, then finer untill you make it up to about 1000 grit, then need to be buffed/polished. Unfortunately the power ball is not going to give you results on them, would more then likely destroy the ball.
Old Dec 4, 2013 | 04:13 PM
spent21's Avatar
you can get the acid from az or o'rielly's... I believe it is called Alumibright (or similar) in a gallon jug... not on the shelf though.
Found it
Superior Products J70-1 - Aluminum Brightener | O'Reilly Auto Parts
Part # J70-1
Old Dec 6, 2013 | 11:30 AM
slpsilverado's Avatar
Originally Posted by JurgenS
The result is truly amazing, a few pics of the process:
It's done in different steps, with different polishing stones. Depending on the state of your wheels, it can take more than 24 hours of work to complete.
How much does this usually cost? That is an incredible difference.
Old Dec 6, 2013 | 12:34 PM
j.mo's Avatar
I wonder if something like a soda blaster would work.
It's very gentle on the metal but produces great outcomes.
For example, you can blast the paint off a soda can without harming the metal. We used to use one at work to blast/clean delicate metals and tanks.
Soda blast away all the bad metal, should leave you a nice clean smooth surface to begin the polishing/buffing step.
Old Dec 6, 2013 | 01:35 PM
JurgenS's Avatar
price really depends on the state of your Wheels. It costed me 500 because the wheels were far gone.
Old Dec 6, 2013 | 02:14 PM
TXsilverado's Avatar
this stuff looks like an easy way out to the heavy stuff too.
Truck Washing in Corpus Christi Texas by Superior Power Washing - YouTube
Old Dec 6, 2013 | 03:17 PM
1bad2k's Avatar
should be doable if you see the result I got on my wheels.
Before
After
Don't know what the process is called but the wheels are put in a barrel with little polishing ***** and then they let the wheels turn around.
Damn, there is absolutely no better wheel finish than polished aluminum. I hate my chromies. Maybe when I finish the rest of the truck I can get some billets for it.
Old Dec 6, 2013 | 04:10 PM
there is nothing more annoying than cleaning billet.
Old Dec 6, 2013 | 04:57 PM
OK, i would love to see someone build one of these tumblers and report back
Vibrating Polishing Machine Homemade
Old Dec 6, 2013 | 07:18 PM
1bad2k's Avatar
Its therapy! Lol. I enjoy it.
