bowtie
Old Oct 31, 2005 | 07:15 PM
Mvp's Avatar
Mvp
Default bowtie
im having trouble taking that darn thing off can somebody help?
Old Oct 31, 2005 | 07:17 PM
TXsilverado's Avatar
remove the entire grille and it just unclips from behind. you might be able to just pull up the plastic covor going from the core support to the top of the grille and reach in there.
Old Oct 31, 2005 | 07:18 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Two clips you squeeze them together and it pops out. Like tx said its easiest witht he grille out.
Old Oct 31, 2005 | 09:10 PM
Mvp's Avatar
Mvp
it dont have clips it gots some lil bolts in the back
Old Oct 31, 2005 | 09:13 PM
1slow01Z71's Avatar
what year?
Old Oct 31, 2005 | 09:17 PM
Mvp's Avatar
Mvp
what year?
its a 2003
Old Oct 31, 2005 | 11:05 PM
Post
I just pulled the plastic wind deflactor and had easy access to the two tin style nuts that were threaded onto the plastic studs that is attached to the factory bowtie. A 10mm socket if I recall should take the nuts off.
If all else fails, take a pair of wire dikes and cut them off.
Jim
Old Nov 1, 2005 | 12:10 PM
Mvp's Avatar
Mvp
Jim
thanks for the help
Old Nov 1, 2005 | 02:39 PM
stone150's Avatar
mide seemed to be melted or glued on from the back
sprayed99
Sep 14, 2015 12:36 PM
wrb002
Aug 25, 2015 03:56 PM
Ketis
Jul 23, 2015 12:37 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
