AUTOMETER COBALT Installed in 2000 S10 Dash
it was pretty easy. if you pop the trim panel off and look at the back side there is a injection mold line on the part that needs to be trimmed to give it the flush mount look like i did. i just trimmed that with a dremel and used an air grinder with the scotch brite brillo type pads to sand everything flat and level the used some jb weld for plastic to attach the acrylic sheet that i bought from hoome depot.
Looks great.. what pcm are u using trying to hook up my tach as we speak and cant get it to work.. I tapped into pin 10 white wire.. put the tach to the 4 cyl and just sits at 3000 with the truck not running...
At the time I was using the msd 6010 and just hooked the tach input wire to the to the tach out wire on the msd and the tach worked right out of the box... I blew up the motor with too much timing and too much boost and shitty gas. When I get back from overseas the truck is getting an all aluminum 5.3 with microsquirt and 80lb injectors since the carb **** is for the birds.
lxcoupe
Jul 21, 2015 02:12 AM
