2" drop in front = needs a lot of alignment work?
Old Jan 14, 2004 | 11:38 AM
Oh, if you got new springs or torsion bars on the truck, get it aligned but be aware the truck will settle completely only after a month of driving. Most people say one week is fine, but I got a bad shake on mine, about 3 weeks after the alignment. It turns out my Hotchkis springs settled a little more and threw off the camber which affected the toe, causing the shake.
Just make sure when you get it aligned that they do a complete alignment to spec. A lot of shops will just do the toe, and leave the camber alone since it still falls in specifications, but all alignment specs should be equal from one side to the other, and it will make a dramatic effect on the way the truck drives and handles.
Old Jan 14, 2004 | 02:18 PM
Y2KSierra's Avatar
Originally Posted by Pro Stock John
But it would be drivable if I could not get the alignment done for say a week?
It should be drivable just fine, but you will be creating extra tire wear while you are driving it out of alignment. My tires were horribly cambered in after my 4" drop, but the alignment shop was able to easily get it back to proper alignment. A 2" drop shouldn't create any issues at all, just make sure to go somewhere you trust, as always.
GMCSIERRA5.3
Aug 7, 2015 01:50 AM
Ammadien
Jul 22, 2015 08:50 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
jovanny
Jul 9, 2015 05:49 PM
