03 Yukon - Gauge Cluster Bulb went out..what to do
Old Aug 7, 2008 | 06:04 AM
04BlackSilverado's Avatar
99-02 -- Twist-Loc Bulbs, Very easy
03+ -- Soldered Incandescent Bulbs
I have done a few 03+ Blue LED Clusters.
Its a lot cheaper than buying a new cluster.
Or I can solder a new bulb in for you for cheap.
PM me for details
Old Aug 7, 2008 | 10:26 AM
12 Second Club
actually went ahead and bought the used denali cluster thru another salvage yard that i do business with....for dirt cheap.. it'll do for now, and give me trans temp for towing, so I'll be happy, for a while, lol thanks everyone!
i'll keep ya in mind on the LED swap, thanks bro!
Old Aug 7, 2008 | 11:05 AM
Tootall's Avatar
I've done several . . . they're not too hard
Here's an 03 and up cluster
Old Aug 7, 2008 | 04:00 PM
12 Second Club
not too crazy on the hot spotting...any fix for that?
Old Aug 7, 2008 | 04:04 PM
Tootall's Avatar
yeah, smaller LEDs, and aiming them
Old Aug 10, 2008 | 04:10 PM
Yeah you can run smaller LED's with a wider viewing angle, like these....
Old Aug 12, 2008 | 09:36 AM
12 Second Club
k, new question....put the denali cluster in last night, everything works fine, but the idle was off for a little bit, very rough idle, and the RPM needle was jumping.....is there an idle relaern procedure necessary, or does the cluster even have anything to do with that???? also feels like shifts have changed....and when you let off the throttle and get back on, it hesitates...
doesn't seem like cluster could have anything to do with this, unless some of the trans info or rear end gear info is linked to the cluster somehow...
looks damned good tho!!
Old Aug 13, 2008 | 09:02 AM
I am pretty sure the info is stored in the PCM and not the Cluster (except for mileage).
All else fails, put your old cluster back in and see if it changes back.
Post up pics of how yours looks when installed!!!
Old Aug 13, 2008 | 12:45 PM
12 Second Club
well whatever it was, cleared itself out...will try to get pics tonight. really digging the look of this cluster at night vs. the stock one
calsdad
Jun 14, 2023 11:07 PM
dantheman1540
Feb 24, 2016 09:56 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
andrewlong
Sep 8, 2015 10:25 PM
