***Truck Wheel & Tire Weight Thread***
Ok guys here it is. No more searching through a bunch of posts to try and find the info you need.
Please keep in mind that the weights are user submitted. If you have any wheel and tire info you would like added to the list just send me a PM and I'll put the information on the list. Thanks!
Ok, the wheel weight list is coming back and in better form. I'm going to add a few more sections like bolt pattern and spacing. I'm hoping to have this on it's very own page and not be a thread which would give me more control over it's management. I'm also hoping to be able to have a user input section where you can post your own data instead of giving it to me. Then all I'll have to do is mild editing of the submissions. Enough of my rambling, I'm going to open this thread up so I can hear your suggestions if you have any.
BTW, PLEASE do not post any wheel/tire info up while this thread is open. It's been opened for the sole purpose of hearing your suggestions. Any wheel/tire data posts will be deleted. Continue to PM that info to me so I can add it to the master sheet.
I don't think there is a need for the "w/tires" column, is there? Bolt pattern sounds good since you could have the same wheel, same size, in two different patterns.
I would like to see more individual weights, but that really depends on your sources. I will have some info coming your way tomorrow.
I will definitely be adding bolt pattern and spacing columns. Especially now with the different truck makes about to be in the list it will be handy to know what vehicle the data relates too. I won't be adding a backspace column though. That has little to no bearing on the weight of the wheel.
I'd like to see more individual weights myself also but I can't expect everyone to do that. You're right the list is completely user driven so we have to go with that. The list was never intended to be 100% accurate rather it was meant to give everyone a "good idea" what one wheel weighed versus another wheel.
BoostedBowTie
Jan 3, 2020 06:46 PM
Steve-O-08
Apr 19, 2018 09:32 AM
Corvette454l88
Sep 1, 2016 01:24 AM
