408ci. Build Up Q&A
I will soon begain working on a 408 for my Procharged 00' R/T, and just wanted some insite from all you guys who have taken the 408 path. This is what I have so far..........................aluminum R/T heads "Ported", M-1 4BB "PortMatched", Mild Street cam (Not sure on the size yet, maybe around .480-.500 lift area), bigger throttle body, a much small blower pully (12-13PSI) & Copper head gaskets. I would like for the compression in the new motor to be around 8.5:1 so I can get away with the much higher boost level safely..... Any suggestions would be great.
I assume you have strengthened the bottom end... Crank, rods, pistons etc?
Cam is a little small but should work fine, you can certainly go bigger especially with more cubes now available.
Add a windage tray while you are at it and of course a new oil pump.
12-13 lbs is likely about the max our heads can withstand and still stay attached to the block due to the poor bolt pattern.
Copper head gaskets are not necessary but your choice. Felpro 1008's will handle the duty just fine.
K.J
K.J
K.J
Originally Posted by bad360rt
Yup, I'm pushing around 12lbs or so on the Felpro's with MP bolts, no problems so far. I need to start saving my pennies and collecting parts for a forged stroker shortblock, and maybe a lil more portwork on my heads
Do you still have the stock bottom end
. If so, I had no idea they could handle that kind of power. RTSPEEDDEMON
What compression ratio & throttle body size did you go with on your setup, also who did you buy your kit from? Good stuff thanks for the help
1st thing, don't waste your time with the aluminum mag heads, they are total and utter crap. If you want aluminum heads look into the indy 360-2 and run the 360-3 intake manifold with them.
Simpler solution is to stick with 2.02 r/t heads.
408 can handle a lot more cam than a 360, let that thing BREATHE. 212/218 .560.560 114 would be very very tame and work well with the blower.
58mm F&B or an accel/accufab 4bbl T/B
Im not familiar with a chrysler based 408 but that cam looks tiny I couldnt imagine you being able to even fill the cylinders with enough air seems like it would only hinder power production especially at higher rpms
Bad360RT
RTSPEEDDEMON
.You can contact him at sales@db-performance-eng.com
TB is a F&B 52X55mm, compression is lowered to 8.5:1
. The largest cam I would go with would be .525 lift and most likely hang with a 55mm throttle body on the 4bb M-1.
Bad360RT
The reason for the smaller cam is due to the fact my truck is my daily driver, I agree a much biger cam would produce more power, but would greatly hender the drive ability of the truck
