ZL1 Colorado: take 2
#132
pierburg cwa400 - i think is the pump hes referring to, oem for a few manufacturers. simple power and pwm control connections. they also have a mini controller thats reasonably priced as well
also, that turbo placement is tiddies
#133
Yeah it's the CWA400, same one Atomic runs for his intercooler. I have another one for my IC that I still have to install. Pump was $70 on eBay for a legit Pierburg and I made the controller myself. Super cheap for a strong cooling solution.
#138
Custm2500's Rude Friend
Had this issue with the turbo truck after "some one" Bent some rods when it went lean.
Went to Oriley's and got the longest set they had. There listed at 12 but I think that was between the boots and not overall.
They where longer than the "Long" factory wires. Maybe try that.
#139
Welp it finally runs, albeit without a belt and on a battery charger. I had to bend up the power steering pressure line to fit with the blower stuff and its too haggard to seal now in the stock location. Ended up cobbling something together to get the truck operational with the square coil plug wires...
Plug wires, coil pack mounting, coolant reservoir...basically everything on the passenger side of the engine bay will need to be redone but this will make sure it is mobile enough to move to the new house in a couple weeks.
I can grab the turbo shaft at idle and stop it, and it stays stopped until I rev it back up.....its gonna be a laggy *****. Have a nitrous kit to install yet though, that ought to save me some spool time. Horn and hood latch still fit
