wrecked my ss
#61
Smart move getting a NEW frame. My brother-n-law put a junkyard frame under his Yukon after his wife wrecked it and come to find out it was "tweaked" as well. He had to basically do the job twice
I'm sure it's hard to stay calm when you're looking at your truck that you've sunken' ten's of thousands of dollars and tons of time into and it's basically in pieces. At least you're getting it fixed, and fixed RIGHT! Looks like the old saying will be coming true, "What ever doesn't kill you (the truck in this case) will only make you stronger!!" Good luck guys.
Now what do you do about getting the thoughts of that new Z06 out of your mind
I'm sure it's hard to stay calm when you're looking at your truck that you've sunken' ten's of thousands of dollars and tons of time into and it's basically in pieces. At least you're getting it fixed, and fixed RIGHT! Looks like the old saying will be coming true, "What ever doesn't kill you (the truck in this case) will only make you stronger!!" Good luck guys.Now what do you do about getting the thoughts of that new Z06 out of your mind
#62
Originally Posted by dewmanshu
Quik! Redo his wideband wiring while you are in there. LOL Ground the unit at the OBDII ground and the sensor ground to directly to the battery terminal (in some way shape or form)
#64
Notorious BIG
i told you before man i tried grounding it there already. that was the first placed i tried but still had voltage offsets. i grounded that ******* LC-1 a million times and just so happened that i gave up after connecting it to the firewall stud grounds. still get a voltage offset. quik is not touching my wideband wiring lol
#70
i dont **** around, ask bill or josh. we could of got alot more done today if we went a different route on the cab but its ok. we could as long as they can keep up lol have that truck on all 4s and cab back on chassis by monday and ready to be painted
as for beer none for me, its all about work when im working...besides i dont drink beer
