TVS 2300 + other Goodies in an '04 SSS
Old Jun 4, 2014 | 08:35 AM
  #31
BigKID's Avatar
The cam specs seem to be inline with the current trend for pd setups. Just for comparison, my cam spec'ed for TFS235 is 225/243 .621/.627 117+5. I am not sure what lobes Geoff uses now but he used to have some pretty aggressive proprietary EPS lobes. I would be sure to get good lightweight roller rockers or trunion upgrades for stock and a 3/8 pushrod to keep the valve train stable.
Old Jun 4, 2014 | 09:14 AM
  #32
Razor's Avatar
BMF
My cam specs are 231/248 .617"/.595" 120+5
2.3 Whipple on a 6.0
Old Jun 4, 2014 | 09:30 AM
  #33
L8ERBRO's Avatar
I was thinking Harland Sharp rockers and that's what I put on Geoff's spec sheet. Is that a good choice?
Thanks guys - how would you say your rides idle...got any vids to post?
Old Jun 4, 2014 | 10:50 AM
  #34
BigKID's Avatar
Some pros say the HS are a little heavy on the nose if you are going to spin it high. What rpm did Geoff say it should make peak power and expected shift point? You can use the stock rockers with trunion upgrade for weight savings but you will need to order your heads with powered metal valve guides.
Mine is not running yet but should have first startup this weekend. :xfings:
Old Jun 4, 2014 | 11:18 PM
  #35
Razor's Avatar
BMF
Smooth idle, hardly any lope. Pulls good vacuum and no noticeable drop in power in upper RPM.
Old Jun 5, 2014 | 09:28 AM
  #36
Razor's Avatar
BMF
Was thinking about it...and remembered I do have an idle vid! My intake is one of the loudest things on the car, under the hood, with the electric fan being a close second. Drives me nuts
https://www.youtube.com/watch?v=bqt5...ature=youtu.be
Old Jun 5, 2014 | 12:10 PM
  #37
L8ERBRO's Avatar
Finally!!!
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old Jun 5, 2014 | 01:32 PM
  #38
L8ERBRO's Avatar
You're Camaro's bad *** bro...love it!
Old Jun 6, 2014 | 07:47 PM
  #39
L8ERBRO's Avatar
Took off work early today and got a few hours in on the Maggie install...
Got the tank re-installed and will pop the hood tomorrow morning bright and early!
File Type: jpg
Old Jun 6, 2014 | 09:23 PM
  #40
Vortec350ss's Avatar
Yea I'm surprised how little it lopes honestly. Good stuff.
You must be pumped it came. It'll be up and running in no time. You must be psyched.
