Steve-o-08's Silverado Build Thread, Take Three.
#242
Curious on the faster ratio rack you were looking at? Was it an aftermarket rack or a stock piece off another vehicle that could be made to work? I was considering modifying the column with a quickener. probably 1.5:1. Would have to pull the column out to see if was even possible.
#243
ahhh, thanks. Sweet truck,which happened to lead me to this forum after I started looking into making my 94' rcsb handle better. I Autocross my 99' Miata already so I'm desperate to make get rid of that squishy feeling the suspension has.
#247
Just found your thread and read through it all, now I'm late for work.
Question: did you ever get around to cutting the tranny crossmember mount and plating it in so it's flush with the frame? I wanted to know if it was possible to get it flush with dirt tracks tubular member because it's hard to tell looking at pictures of the flanges allow it
#248
Haha nice. Sorry about that...
I haven't cut off the crossmember mounts yet. Still on the to-do list. If the mounts were off I believe the tabs on his crossmember would be slightly lower than the frame rails. If I had to guess I would say less than an inch. I would have trimmed the crossmember down if I needed to.
#249
