Slow and getting slower
Old Jun 15, 2012 | 04:56 PM
  #991
NightmareTBSS's Avatar
Originally Posted by sprayedenali
wait wut?
Something fishy going on around here!
Old Jun 15, 2012 | 05:59 PM
  #992
TTownTech's Avatar
Pipebomb throttle bodies, and midgets filming street races?!?! I gotta go stock up on popcorn, this is something worth watching!
Old Jun 15, 2012 | 07:49 PM
  #993
03sierraslt's Avatar
We like to keep things interesting...
Old Jun 15, 2012 | 11:45 PM
  #994
silverado-lover's Avatar
So much awesomeness
Old Jun 16, 2012 | 06:53 PM
  #995
custm2500's Avatar
Ph.D. in HUBRIS
Originally Posted by Spoolin
Having a remote trigger for the camera has nothing to do with editing video's genius, it has everything to do with the size of the memory card and the batteries on standard GoPro's. But you wouldn't know that because you obviously have very little experience with afixing and using GoPro camera's on vehicles or you wouldn't be saying a remote button is dumb so STFU.
And the fact that you talk out your *** BEFORE doing research is pretty annoying, most people learn something before commenting on it, not you though, you'd rather cut 12" holes in frames and use pipe bombs for Throttle bodies and then see if it's a good idea.
The original Gopro doesn't offer a remote. That was the last I had looked at them sorry that I didn't do some more research that the two newer styles have remotes.
My original comment was still intended more to the fact that so many people don't take two seconds to edit the crap out of the video. I realize it didn't come accorss that way but that was the bigger pet peive that I was expressing.
People regularly cut an actual 12"s or more out of there frame and plenty of them then pull a trailer! Wow isn't that amzing! Maybe I am not the only one who can research and think things through before making a comment. I am sure you have seen plenty of step notches and maybe event a few of them with a trailer hooked to the *** end.
Back to the original topic. I agree that if you have the newer gopro capable of using the remote it would be a nice feature.
Old Jun 18, 2012 | 08:12 PM
  #996
Atomic's Avatar
I have a gauge for that
I ended up putting the 10" straps back on because the 12" ended up being 12.5" and too long at any rate. It looks like the 10" will fit perfect and leave me room to tighten things down.
Took it out last night to play with it and 20psi is just freaking nasty, 65mph rolling burnouts
I replaced my TPS sensor today because last night the lowest it would read (with the throttle closed) was 9-13% which makes my idle suck because adaptive spark idle doesnt kick in...also screws with the shifting.
Old Jun 18, 2012 | 09:35 PM
  #997
JFOLM's Avatar
Richard, what is the specs on your short block?
Old Jun 18, 2012 | 11:10 PM
  #998
Atomic's Avatar
Iron 6.0 truck block, forged Weisco pistons, forged callies rods, and forged k1 4in crank machined and assembled by LME.
New injectors are done at 20psi with 55% e85...
Old Jun 19, 2012 | 12:12 AM
  #999
smokeshow's Avatar
Mod with training wheels
Time for some 160s.
Old Jun 19, 2012 | 12:45 AM
  #1000
Atomic's Avatar
About to get nerdy...
I made a plot of dyn cyl air versus rwtq based on my dyno runs. I found a very strong correlation with an r squared value of almost .98 using about 12 scattered data points. With this number I found my run tonight at 20psi to be around 930ftlb and 1030hp. This was a 3rd gear pull from 75mph so it was past peak torque by the time boost was fully up, but the peak hp number should be right. I'm not sure what goes into the dyn cyl air calculation but the trend holds from 100 to 700 ftlbs based on my data gathered from my dyno time.
