simple 2018 Black Edition
#41
I'm still on the stock converter. I pull a snowmobile trailer alot in the winter and dont really wanna go with too loose of a converter. What kind of stall were you planning on going with. I 60' right around 1.8.
#42
Was looking at the TCI converter, . I’ll be towing a little car at the most.
https://www.tciauto.com/bolt-togethe...all-range.html
#43
Curious to see what gains you get with that. I read online that the stock converters on these trucks were 2600 stall. Just tried it on my truck and I can brake stall it to around 2000 rpm before it pushes threw the brakes.
#48
Trav, what size shot are you planning on running? Probably the most time consuming part of the nitrous install is running all the wires into the cab.
N/A you run a very similar time to me. I'm a crew cab with a 6.2 L. I guess they equal out.
#49
I will be on a small shot, 100-125. Cant really see in the picture but the Lingenfelter LNC is installed so I can pull timing. Not many new GM trucks out there running nitrous from what I could find searching the forums
#50
I was looking for the LNC in the picture but couldn't see it. I am running the LNC as well. You must have tucked your wires better than I did.
Are you running a window switch as well? Looks like we have pretty much the same nitrous set-ups.
