Rob's Turbo GMC Sierra RST Project
Old May 31, 2010 | 10:01 PM
  #21
_zebra's Avatar
makes children cry
i've seen a couple turbo guys go all the way back up to 3.42s
Old Jun 9, 2010 | 12:15 AM
  #22
foose04's Avatar
Update: Posi is in, loving that! However, still not a lot of traction, but much better.
Also, strapped the truck down to the dyno:
Here's the thread with video: https://www.performancetrucks.net/fo...13#post4476613
Old Jul 26, 2010 | 08:34 PM
  #23
foose04's Avatar
Next Update: Removed Kenny Boost-A-Pump, installed another walbro 255. Also installed stronger wastegate spring. These runs made at 15 PSI.
Video: http://www.youtube.com/watch?v=V9nRm6vZl_I
Dyno Graph:
Old Jul 26, 2010 | 08:36 PM
  #24
foose04's Avatar
Also, the baby turbo likes it's bottle to. Added a dry shot. Started with 35 jet, then 50, now at 75jet and 15psi boost. I re-drilled my T-Stat, truck truns around 175 now. Also AIT only raise about 5 degree nows on a 3rd gear pull when spraying.
Old Jul 26, 2010 | 08:44 PM
  #25
charcold-bowtie's Avatar
I assume you went to return style?
Old Jul 26, 2010 | 08:45 PM
  #26
foose04's Avatar
Correct, it's be return since turbo install.
Old Jul 26, 2010 | 08:47 PM
  #27
What did u do with wiring at the tank? i plan on putting a big external, and a hot wire kit. Just use the stock power wire to "trigger" the relay? and leave the rest of the wires hanging?
Old Jul 26, 2010 | 10:36 PM
  #28
foose04's Avatar
I use the stock power wire to trigger a relay also. The pumps have a 8 gauge feed power wire direct from battery. The top of pump housing is drilled for the wire and 8an fuel line connection. Inside the housing is Y'ed to the two walbro's.
Old Jul 26, 2010 | 10:59 PM
  #29
A Low Dime's Avatar
13 Second Truck Club
HAHA And you said you were going to dial back the boost once you played on 15psi and got a 600rwhp dyno........now look at you, added some nitrous ON TOP of 15psi LMAO
Old Jul 26, 2010 | 11:12 PM
  #30
foose04's Avatar
Lol, well damnit it was sitting in my gargage and it was calling my name everytime I walked by it. Besides, I only spray it when i'm having a boring or shitty day lol. Also makes my Borla exhaust a little extra throaty when it hits!
