RCSB build
Old Sep 24, 2012 | 02:47 PM
  #591
smokeshow's Avatar
Mod with training wheels
Thanks lol. I'm not exactly sure why it came out blurry...it was my friends phone and has taken good videos before. I just posted it cause these turds wanted to see a video
Old Sep 24, 2012 | 03:35 PM
  #592
black00chev's Avatar
Slowest turbo build ever!
You must be going SUPER FAST cause all I heard was wind!!!
Old Sep 24, 2012 | 05:48 PM
  #593
mitchellmade's Avatar
MASS seller approved
still a 4.8 in there?
Old Sep 24, 2012 | 05:55 PM
  #594
smokeshow's Avatar
No, its the L76 6.0.
Old Sep 24, 2012 | 09:06 PM
  #595
oakley6575's Avatar
Cool man! sounds great
Old Sep 26, 2012 | 03:07 AM
  #596
smokeshow's Avatar
Truck is feeling really good. Did some more trans tuning tonight to get it to where I wanted. Converter lockup with the old trans was soft and mushy and didn't hold torque...definitely a thing of the past lol. First time it locked I thought it was going to break something. Had to dial back the PWM a little bit to soften it up.
Turned the **** up to 14psi and it pulls hard, but definitely spools noticeably slower now I may have to bring the bottle out this weekend when the boys go out to play lol. Nitrous is going to be a necessity at the track now if I'm going to be cutting any reasonable 60' times, at least until it cools down more. DA is 4700ft right now, and with my foot basically on the floor for almost 4 seconds it only managed to build like 4psi. I can hear a couple exhaust leaks so I am going to get those patched up and see how much it helps. With half the cylinders feeding a turbo I'm thinking an exhaust leak is going to hurt much more now. Timing tweaks should help spool out somewhat as well..
I'm gonna throw some E85 in my nitrous fuel tank instead of methanol and swap the fuel jet with the nitrous jet...should net like a 75 shot. Ought to be fun with 14psi. We'll see if that 9 second cobra wants to play this time
Old Sep 26, 2012 | 03:12 AM
  #597
smokeshow's Avatar
Also, Mitch never mentioned/asked about it til I had the kit installed, but it sounds like boost bounces between turbos! If you slowly let out where on a single turbo setup you'd have BOV flutter, the pressure seems to bounce between compressors. Weirdest thing to hear when you're cruising along with the windows down, roll out of the throttle and hear that air rushing sound alternating between two sides of the truck
Old Sep 26, 2012 | 10:51 PM
  #598
SCREAMINXL's Avatar
Probably fighting for air............
Old Sep 26, 2012 | 10:58 PM
  #599
AndysC3's Avatar
Did you do a dual in single out intercooler? looks like you took the drivers side over and had the passengers side turbo t into the pipe. where is your BOV?
Old Sep 26, 2012 | 11:38 PM
  #600
smokeshow's Avatar
Single in, single out. BOV is right after the turbos tee into the cold side.
