Project "Rebel Yell"
RedXray (06-26-2020)
#174
100% Redneck
Well another full day... almost there!
Finished underneath with the oil pan, rack & crossmember. Up top... front cover, balancer, headers, water pump, coolant bypass, dip stick.
Tomorrow... pushrods, rockers (double check lifter preload), intake, power steering and alternator, plugs & wires, covers & coil packs, radiator & e-fans, belts & hoses, add coolant & oil, load tune with -4 degree timing, bust gasoline, tune MAF, VE & spark, burn rubber, drink beer.
#176
100% Redneck
Little set back... the 7.500 pushrods I got are a little short giving me around a .030 preload, a few cylinders above and a couple just below. Morel wants .030 - .040 for an iron block aluminum heads. The aluminum block guys shoot for around .050 thousandths. Martin @Tick performance says .030 to .060 for morel's is fine.
I'm shooting for .045 to 0.50. BTR pushrods go from 7.500 to 7.550 so that's to big of a swing. Trick Flow has the 7.525's so some will be a little over my target a few under. Could order perfect individual custom lengths from Manton but they're prices are above my budget. Summit says they'll ship on Monday.
Jeebalow (06-28-2020)
The following 2 users liked this post by RedXray:
dantheman1540 (07-01-2020),
Jeebalow (07-01-2020)
RedXray (07-01-2020)
#180
100% Redneck
Pushrods came a day early so I was able to button everything up but have to wait until tomorrow to fire her up. Yesterday I was fighting to get the "hacked" EVAP connected. With the V6 trucks you have to splice in the EVAP. Trying to get the tube into the rubber splice my hand inadvertently broke the plastic clip for the 3/8 fuel line.
Bought both the feed and return -6 an fittings in case the other plastic clip is brittle.
Both fittings should be here tomorrow.
