Project "Rebel Yell"
Old 06-16-2018, 08:05 AM
100% Redneck
RedXray's Avatar
Received 1,331 Likes on 793 Posts
Default Project "Rebel Yell"
I swear down here in the south there's dam near a truck in every gosh darned driveway... this one is mine.
"Rebel Yell" is a 100% southern truck commandeered from the Fort Wayne Indiana assembly plant just north of the Mason Dixon Line in the year two thousand.
Started life as a 200HP 4.3 V6 that suffered from the Dexcool induced intake gaskets weeping, still ran excellent but "Rebel Yell" needed something more as it had the suspension drop, Denali conversion bumper, nice paint (retired body/paint guy) and LTZ 20's. An LQ9 6.0 from a 2005 Escalade was procured, so the build begins.
Tear down and cleaning
Assembly begins:
Sloppy Stage II cam 228/230 .585/.585 112* with PAC 1218 springs.
Click image for larger version
New Throttle Body and 50lb Flex Injectors
nurarihyon (04-06-2022)
Popular Reply
01-20-2023, 07:11 AM
BigRedTruck18
Registered User
BigRedTruck18's Avatar
Hello everyone,
I wanted to share that my father "RedXray" has passed. I want to thank everyone on this forum that conversed with him. He loved anything that had to do with his truck including this forum.
Thanks.
Old 06-16-2018, 08:20 AM
100% Redneck
RedXray's Avatar
Finished with the engine
Speed Engineering Headers and Tru-Duals
V6 out and time to disassemble front end.
Core support removed
Some paint and new corrugated wiring loom
Performabuilt Level II with a Circle D 3200 stall.
LQ9 and Transmission on the hook.
Installed most of the harness and pressed on the power steering pulley. Waiting for new Knock Sensors and Harness to arrive. Test fitted the intake to see where the modified V6 to V8 fuel line fit.
strutaeng (09-22-2022)
Old 06-18-2018, 09:32 AM
BigBlock90's Avatar
Very nice project and good lookin truck!! Should be a stout runner with that combo.
Old 06-19-2018, 02:05 AM
100% Redneck
RedXray's Avatar
Thanks fellow Carolinian
Today's finished work: AC Delco knock sensors installed, intake, injectors connected & coil packs, new PRNDL switch, trans wired, torque converter bolts, starter, crossmember, belts, test fitted CAI tube & fan for clearance = ok. (some owners with the AFE CAI have fan clearance issues)
Tomorrow: Install header & exhaust, o2 sensors, plugs & plug wires, heater hoses, driveshaft, core support, radiator & hoses, fan & shroud, a/c condenser, a/c accumulator, a/c lines, trans cooler, CAI, PCM, fluids, battery.
Old 06-19-2018, 11:07 AM
arthursc2's Avatar
Received 1,434 Likes on 1,062 Posts
why no e-fans?
Old 06-20-2018, 02:13 AM
100% Redneck
RedXray's Avatar
Originally Posted by arthursc2
why no e-fans?
Next on the list after I bust some gas. I need to find a 34" radiator too.
__________________________________________________ ________
Today: Installed header & dual exhaust, o2 sensors, driveshaft. Then filled oil filter to finish underneath.
Up Top: plugs & plug wires, heater hoses, oil dipstick.
Should finish up tomorrow: core support, radiator & hoses, fan & shroud, a/c condenser,
a/c accumulator, a/c lines, trans cooler, CAI, PCM, front bumper, fluids, battery.
Old 06-20-2018, 10:55 PM
Feed's Avatar
Nice build, awesome garage
The following 2 users liked this post by Feed:
RedXray (06-20-2018), strutaeng (09-22-2022)
Old 06-20-2018, 11:53 PM
100% Redneck
RedXray's Avatar
Thank you sir
Almost finished...
Tomorrow:
Install battery, engine oil, coolant, transmission fluid, turn key to start position.
Old 06-21-2018, 07:29 AM
ILuvJDM's Avatar
Finally, an engine fitting of the exterior of the truck
RedXray (06-21-2018)
Old 06-21-2018, 02:26 PM
97_ek's Avatar
What a clean setup! Truck, motor, and garage look great
Quick Reply: Project "Rebel Yell"
