Project Kermit
#701
well then at least you didnt post pics of abunch of dudes like you did before of when you went to that gay parade
damn it wish i did cutouts and my truck is still not loud enough
you better post some vids cause if the magnaflows sound good im buying a set to hell with these damn no name brand blowmasters sorry just letting off alittle steam
#702
GFYS and STFU
#704
#705
YES, yes indeed!!! more pic of these two!!! the one in the yellow is cute as hell, so when r u and neighbors having another g2g
lolz @ this!!! sorry Jules but thats pretty funny, messed up that u ended up passiong out at the club and probably missed a lot of action but funny nonetheless...
-Rob
??? -Rob
#708
GFYS and STFU
Kinda looks like it but there was a pretty even mix, there were a few more behind me and a couple way in the back. I stopped at the shop this morning and he's got some of it mocked up and more importantly he has the cross-member fabbed up...IT IS BEAUTIFUL!!!
Here is the old one for comparison...
And the new one!!
Reason for the new cross-member is because since I'm going with dual exhaust the driver's side couldn't go above the crossmember due to the ABS and wiring harness and other misc stuff. So it would of had to of gone under the tranny crossmember and I only have 6" of ground clearance to begin with on that member, so minus a 3" pipe and a little bit of clearance so the pipe isn't hitting against the cross-member and I would of had about 2.5" of ground clearance from the bottom of my exhaust to the road. So speed bumps would be impossible to go over. So he fabbed up this new crossmember and now I can easily fit this in it!! ...
As you can see it fits mostly flush with the bottom of the frame so the exhaust won't be a low point...
The lowest point of my last truck was the Y-pipe and after too many speed bumps I did end up bending it out of shape so I won't have this problem now!
Here is my last set-up and you can see the Y was the first thing that hit when I bottomed out!!
Don't have pictures of much else as of yet but there is the muffler, it's a 2-in-1 Magnaflow, biggest one I could fit in there to try and mute/muffle the exhaust as best I can.
I kinda hope it will be rather quiet with the cut-outs closed so that I can drive it around normally without attracting too much attention. And when I need to I can open the cut-outs and be as loud as can be!
Not sure what to do with the dump over the axle but think I'm just gonna dump it at a 45 degree angle towards the rear, and keep it high enough also so it stays hidden.
Made a rookie mistake and drank a 1/4 bottle of Cuervo in an hour. Hadn't been drinking in such a long time I got alittle carried away!
