Project JUNKER
Old May 11, 2012 | 11:43 AM
  #51
ak2007r6's Avatar
This truck is perfect. I would not touch a thing on the body, just make sure everything under it is solid and drive it like you stole it.
Thing is badass man
Old May 11, 2012 | 01:57 PM
  #52
SLCviaAK's Avatar
Because the S10 has modern suspension, brakes, and the frame is boxed in some spots. And the wheelbase is within a quarter inch i think. Im doing this to a 1950 AD also. Snag a $500 or cheaper 2wd reg cab long bed S10, sell off the body if its decent, sell off the motor/trans, swap in V8, explorer 8.8 rear, drop body on, done and done.
Its not quite that simple, but you get the idea.
Old May 11, 2012 | 02:47 PM
  #53
colekill's Avatar
KickinAssAndTakinNames
I have always wanted this.
******* sick
Old May 11, 2012 | 02:52 PM
  #54
ducky's Avatar
Ah I gotcha. Think an ext cab S10 is the same frame size as a reb cab, long bed?
*edit just found some info and I would have to cut portions of the frame to get a Ext cab, short bed under it. Man I wish you could do a write up on the swap. Would make it worth my while haha
Old May 11, 2012 | 05:22 PM
  #55
SLCviaAK's Avatar
I WILL do a build thread on it, once i get off my lazy *** to work on the project. The truck was/is slowly rusting away in my garage. And the donor s10 was my DD for over two years.
It is really hard to get the motivation to do this stuff on the side, when you do it all day at work.
Old May 11, 2012 | 05:24 PM
  #56
SLCviaAK's Avatar
And FYI, there are some build threads on S10 frame swaps on ratrodsrule, killbillet, 67-72 chevy forum, and the HAMB. Among other places.
Old May 11, 2012 | 06:07 PM
  #57
ducky's Avatar
ah yeah I have been finding some decent stuff. Ill probably keep my 51 as is until I really get some funds and time to do the swap. I know it can be cheap if done right
Old May 11, 2012 | 09:49 PM
  #58
SLCviaAK's Avatar
There are two different companies that make "kits" designed specifically for this swap. Advanced design engineering is the one that comes to mind.
Old May 11, 2012 | 11:17 PM
  #59
ducky's Avatar
Yeah I saw ADs stuff, there site sucks to browse through but I will keep poking around. Luckily I have friends like DBRODS out here in Austin that are professionals with speed and chassis' so I don't necessarily have to worry about getting it done incorrectly.
Old May 12, 2012 | 01:50 AM
  #60
SLCviaAK's Avatar
Ya, I'm not using a "kit" because I can do much of it myself. Plus I'm ditching alot of the parts that the kit compensates for. IE- no running boards, glass tilt front end, tubbed out rear, new custom floor and firewall.
