Project Fenrir
#32
#33
So I decided to go with an aftermarket fuel pressure gauge, but I still don't want one of the A pillar gauge pods. Thats a dead giveaway that something is going on. Was searching the web and found somebody that makes gauge pods that go in the dash pocket that pops out. I figured hell, I have CAD and a 3d printer, lets see if I can make one for myself. Here is what I came up with.
This is the gauge pod I designed in CAD.
And this is what it will replace.
#34
What CAD program are you using? I really need one cause I have a lot of stuff I want to design and make
#36
AutoCAD is my favorite cause that is what I learned on when I was in high school. I was using some jank freeware a while ago
#39
I also had a great conversation today with the guys at true blue motorsports. They will likely be doing my transmission work for this build. 6l90 trans, built for 1000 hp, high stall converter, all the electrical, and a corvette steering wheel to give it paddle shift and hopefully keep all the stereo controls working. We will see, but the gearing in the 6l90 is amazing for this build. With the AWD/4WD setup the and the first gear being 4.03 to 1, it should 60' amazingly, Plus it will have a .67 overdrive for long trips. With 35" tires that puts an 80 mph cruise at 2150 RPM. Only downside is its gonna cost me about 8 grand.
#40
All painted and back together
One of the mounts i fabbed
The other side intercooler radiator mount
Transmission cooler turned around to make space for intercooler radiator.
Radio displaying obd2 gauges
Boost and afr gauge on steering column
Switches for relay system hidden in ash tray
View with ashtray closed
Intercooler radiator mock up
De-grandpa of the truck
