Project FailBlazer SS...
Project Failblazer SS!! Stage1 N/A.. - YouTube
Dyno vid... Enjoy! Dyno operator says this equates to roughly 700hp @ crank on his dyno.. (Mustang).. E85 soon to come 450/380 thru a built 4l70e with 4k ptc stall..
Sounds good..
Customers, it's fun as hell!! Honestly has great street manners too. I built it for about a 250shot of spray so that's why torque is a lil low.. But that isn't gonna be till part three rolls around. The motor is fresh with only dyno time on it. Soo gonna wait a bit for that. Next is a custom exhaust and bigger injectors for e85. Hoping that gets it past 500wheel mark.
Well motor ran well for a couple weeks and then it started throwing cam/crank correlation codes. I checked cam timing, and changed cam /crank sensors and PCM. Scoped signals from both sensors and verified sync and they wouldn't sync. Called Callie's and they said the reluctor slipped. I was short on time so had a crank made and balanced off the first one and with a billet reluctor. Pulled the motor and tore it completely down.. Looked like **** inside. Cleaned everything back up and swoped the cranks. The reluctor slipped about an 1/8" wtf total bs right so I tig welded the new reluctor on with two 1/2" beads 180* from each other ground the welds down and called it a day. Re assembled engine still on it's way back in. I'll let you know if it fixed the issue....
It fixed the issue, come to find out the reluctor slipped about an 1/8" and also map sensor had failed too. Parts looked not the greatest inside lots of carbon build up. Got it back together tho.
Took it to the track ran an 8.0@84 1/8 with a super soft launch and some (ok lots) spinning. If we can hook it and use the converter in it we should see some high 6/ low 7s 1/8 mile times. The truck runs very hard for being n/a. Easily throws cammed 5th gens a royal beating. Lol gave lots of butt hurt at the mustang/ f body event In Kc.. love this little truck.
