OBS 97 Z71 05 5.3 and Radix Swap
Old Nov 8, 2010 | 02:07 PM
  #161
exodus's Avatar
My 05 5.3 computer through the Speartech harness controls the trans. All plug and play...just have to swap on the old connector for the VSS if you are using the old style 4L60.
Old Nov 8, 2010 | 02:49 PM
  #162
AKlowriderZ71's Avatar
11 Second Hall Moniter
I see a cowl hood there. Any hood clearance issues with the stock hood?
Old Nov 8, 2010 | 04:16 PM
  #163
KDavis04ss's Avatar
I read back on page 7 I think that you have a set of the shoenfield headers (spelling?) for OBS trucks that you cant use? I know its been close to a year but do you still have them a might want to sell?
Old Nov 8, 2010 | 07:29 PM
  #164
the_reaper's Avatar
Nice build exodus, I see you looking for a tuner in WA, Call http://trifectaperformance.com/ his name is vince I do think he is a sponser on LS1 tech. Great guy and really knows his stuff..
Old Nov 8, 2010 | 08:32 PM
  #165
1989k1500's Avatar
Didnt you need signal from the brake switch or anything else?
Old Nov 8, 2010 | 08:49 PM
  #166
exodus's Avatar
The stock hood barely touches...if the engine sat about 1/2 inch lower it would be perfect. The motor mount adapter plates I went with from S&P is what made me have this issue. by putting a small dent in the hood bracing in a spot the size of a dime would make the stock hood fit fine, I needed the new hood anyways so I couldn't pass up the steel cowl made by Harwood that I got through summit racing for $290.
  #167
exodus's Avatar
Sorry man, I had to send them back to get my refund.
Old Nov 8, 2010 | 08:51 PM
  #168
exodus's Avatar
Thank you so much for the lead...I will definitely follow up. If you can please PM me with the link and name as they are not a sponsor for this particular board. Thanks!
Old Nov 8, 2010 | 08:53 PM
  #169
exodus's Avatar
No...the brake switch is all hooked into the body harness of the truck with the exception of the cruise wires that get hooked into the Speartech harness as I have a DBW setup.
Old Nov 8, 2010 | 09:19 PM
  #170
1989k1500's Avatar
Oh ok, I thought it would need brake signal to unlock the converter.
Your cruise works huh? Thats awesome.
Im about to start on the harness for my 89.
