not a truck but it is a truck motor
#153
single digit dreamer
in a week or two we should have a chart with the dual fuel change over to race fuel and then do another where we change from pump to meth. should be some neat info. looking at that chart we might need to spin it a little higher
#154
9 Second Truck Club
very fun day at the dyno today. we suspected a problem with our 2nd fuel system and to confirm this we wanted to just tune the car on that system. sure enough it wasn't tuning well. sounded like it was running on 4cylinder once we got off idle. heat gun confirmed this. dynotom busted out his hand held duel trace scope
and hooked up to one injector on each bank and right away showed we were not geting the "peek" of the peek and hold on one bank. ******* squirt
this made us very happy since now we know what our problem is.
the phased fuel is going to be easy and work well once we get that fixed.
just to have some fun and to test out the rest of our 2nd fuel system we hooked up the injector harness from our primary fuel system to our 2nd fuel system and made a few runs. this means we were running off of only the 8 injectors that are higher up in the runner and we were running off of the big fuel system and on race gas. even though the car will never idle on these injectors it still idled pretty good and was easy to tune.
numbers... 508rwhp(mustang) at 10psi, no intercooler, 214deg peek iats. this was on race gas. we plan on running on meth, not race gas. meth should be good for AT LEAST 50rwhp more at the same boost level. at 10psi i think we are headed for 560+rwhp.
just for refrence the fairmont with an intercooled 5.3/mp70 and the same cam as we are running now was at 458rwhp@10psi on the same dyno. different tranny and converter but it is fun just to compare.
very fun day and thanks to tom at c@s
and hooked up to one injector on each bank and right away showed we were not geting the "peek" of the peek and hold on one bank. ******* squirt the phased fuel is going to be easy and work well once we get that fixed.
#156
the engine is suppose to be an 01 but who knows.
nothing new to report. got sidetracked on some other stuff. the car is ready to go back to the dyno and try the duel fuel and then duel fuel meth but now it is blocked in the garage. i have only had 1/3 of my floor poured since last year and now i have the other 2/3's ready to pour but they are not coming to do it till next weekend so the car is blocked in by the rebar and floor heating pipes.
#158
definatly the garage. i have been out there almost every day doing something. i think it will be "done" in a month or so. that does not include the fun stuff like finishing off the inside, bathroom, loft, stripper pole, lift, work bench...
#159
