My SquareBody Project.........DIY budget, driveway build
Old Sep 3, 2013 | 06:50 PM
  #61
moregrip's Avatar
what a rush!
FYI, use a tack rag also known as cheese cloth to wipe down surfaces with some shop air before painting. Most likely whatever you used broke down on the cast iron and you didn't see it before painting over it.
scotchbrite knocked the lint right off.....probably didn't even need to paint......of course I did anyway......turned out perfect!
Old Sep 6, 2013 | 06:15 PM
  #62
moregrip's Avatar
what a rush!
So I wanted to add power steering and air conditioning. Can't afford the A/C conversion right now so I'll only be adding power steering to the little inliner at this time.
Using these brackets:
Old Sep 8, 2013 | 09:42 AM
  #63
moregrip's Avatar
what a rush!
My plan was/is
1. strip/paint engine block
2. strip/paint firewall
3. strip/paint section of front frame where the stock cross-member bolts too
4. strip/paint stock cross member
5. bolt painted cross-member to painted section of frame
6. tape off/cover freshly painted surfaces
7. repeat section by section until complete
Old Sep 8, 2013 | 03:00 PM
  #64
1FastBrick's Avatar
Custm2500's Rude Friend
What's Taking so long???
Old Sep 8, 2013 | 03:22 PM
  #65
moregrip's Avatar
what a rush!
final prep:
  #66
moregrip's Avatar
what a rush!
make shift paint booth:
Old Sep 8, 2013 | 03:23 PM
  #67
moregrip's Avatar
what a rush!
after first coat of KBS frame coat:
Old Sep 8, 2013 | 06:24 PM
  #68
moregrip's Avatar
what a rush!
crossmember
Old Sep 8, 2013 | 08:02 PM
  #69
ak2007r6's Avatar
Looking damn good!
Old Sep 8, 2013 | 08:30 PM
  #70
silveradokidd_4518's Avatar
