My build thread
#42
#45
Todays progress
Got the Meth nozzle and Iat sensor installed
Finished up the intake (turned the old map sensor port into a Vacuum reverence)
Relocated Vacuum assist pump (down pipe was in the way)
Installed intake and fuel lines from Y block and back to the FPR.
ran all boost/vacuum lines to intake
put alternator back on
tightened odds and ends
Wanna say thanks to Steve (mr. P) for the iat and map sensor diagrams for wiring
#46
More today
Relocated the heater hose lines
Ran vacuum lines to wastegates
Test fit the surge tank
Btw that tank was the water tank for the old A2W setup its temporary till i can afford for rick to make me a nicer one all this will be mounted in a aluminum tray and for security im getting a daytona flush lid.
All i lack is welding the 02 bungs to the exhaust and 2 fitting for the surge tank. I also need plug wires can anyone give me a suggestion on a good set i have to have tight boots and if i could build my own that would be better. They need to withstand alot of heat
Still need to order my Optima Yellow top
