My 2007 Silverado Build...again
#365
Well the time came to buy some wheels. Gave Bogart another once over and seen these wheels. I REALLY liked these wheels. I decided to buy these wheels instead of having to tear my truck apart and send the parts out to be welded and redrilled. The cost is about the same, and I won't have to wait for someone to do the work.
The fronts are still a few weeks out. They'll be 15x4
#367
Starting at the top left, going clockwise
grounding lug. all of my grounds go here and I have a 4gauge cable ran to the frame
Continuous duty solenoid. left side terminal has a 4gauge cable ran from the battery to it. That powers that solenoid/relay, my solenoid driver, the bang button relay, the n20 fuel pump, and the ARC relay board.
12 position terminal block. distributes the power(or ground) from everything on the panel to the various components I'm operating.(better than using butt connectors)
solenoid driver relay
bang button relay to bypass the solenoid driver for purging through the motor
n2o fuel pump relay
Ground interrupt relay so the ARC panel will power on and off with the ignition
Relay board for ARC touch panel
6 position fuse block power by switched 12v. It will control my MSD igniton, LC1/gauge and something else I can't remember right now lol
