My 2007 Silverado Build...again
Old Nov 13, 2011 | 09:47 PM
  #271
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Originally Posted by Phantom
I don't understand the point of your post? I have no problem lifting a transmission off the ground. I lifted the 80 from the ground and put it in the bed of my truck when I picked it up. I guess if you can lift a transmission off a 4' tall jack and set it on the ground gracefully, then I guess you're more of a man than me lol
There was no point to my thread other than to give you ****
I was talking about not being able to take the 60e off the trans jack.
Originally Posted by Tootall
try doing that with a 3/4 ton transfer case after the tranny is in ! All kinds of awkward fun
Thats what a trans jack is for, and taking those damn things apart is a PITA. When you did your trans swap did you do the pump rub fix?
Old Nov 13, 2011 | 09:57 PM
  #272
Tootall's Avatar
. . . When you did your trans swap did you do the pump rub fix?
oha crap . . . what's that? . . . got a link?
Old Nov 13, 2011 | 10:03 PM
  #273
1slow01Z71's Avatar
Pump rub video.....explanation.. - Diesel Place : Chevrolet and GMC Diesel Truck Forums
Same problem that the half ton trucks have.
Old Nov 14, 2011 | 02:39 PM
  #274
Phantom's Avatar
11 Second Club
Nothin special but here is how the racepak looks
Top left is the fuel level, bottom left will be water temp on one display and trans temp on another, center will be oil pressure and lower right is odometer and trip. The sweep bar will be rpm on one display and mph on another and visa versa. As of right now it doesn't really do anything special except look cool lol. But with my future plans it will be very beneficial
http://www.youtube.com/watch?v=yUnlO9A4Z-4
Old Nov 14, 2011 | 08:57 PM
  #275
BadAssChevy327's Avatar
I like how you used the stock cluster. Seems very cool. Can you hook a wide band to one? What's the price on it? And I thought they had a harness that plugs in port and no need to hook anything else up
Old Nov 14, 2011 | 09:10 PM
  #276
Phantom's Avatar
11 Second Club
They make an obd2 adapter but its an additional 2-$300. I probably won't be utilizing that system much longer so there wasn't any need for me to buy it. You can connect a wideband to it and display on the dash through racepaks vnet system. Its about $350 I believe. Their other sensors that go with the system are $250. I plan to get a nitrous pressure gauge, fuel pressure(for nitrous side), pan vacuum and wideband. Pretty good chunk of change so it will be awhile before I have them all
This setup I got is the udxsr and comes with water temp sensors, oil pressure, oil temp and displays mph, rpm, odometer, trip, turn signals, bright lite indicator, warning light for oil pressure, water temp and two other programable signals. Also has an output for a shiftlite. It was $725 shipped to my door
Old Nov 14, 2011 | 09:14 PM
  #277
Damn. Way cheaper then I thought they cost. Deff cool. How's the manual in the 80? Did u hook lock up yet?
Old Nov 14, 2011 | 09:24 PM
  #278
Phantom's Avatar
11 Second Club
Everything about this transmission is badass. I have not hooked up the lock up yet. I'll try to get it done this week sometime
Old Nov 15, 2011 | 12:17 AM
  #279
slowlsx's Avatar
You got some pictures of the bars installed? Very interested to see how they work. Considering selling my caltracs for these!
Old Nov 21, 2011 | 02:21 PM
  #280
Phantom's Avatar
11 Second Club
Well, I'm officially in love with my truck all over again lol
Finally got to make some passes with the new setup this weekend. It's A LOT tamer in low gear with the 80 than it used to be with the 60e...Means I can hit it with more nitrous I've put a couple hundred miles on the combo now and made 4 solid passes this weekend and I'm very excited about what I think we'll be able to do with the truck now
A couple vids from this weekend
In my first race against the crew cab, I left on motor and about 100' out turned the nitrous on...Unfortunately, I forgot to open my bottle :-/
Left on motor and turned the nitrous on about 100' out
Silverado Vs Camaro - YouTube
Finally left on the bottle
Pontiac G8 Vs Chevy Silverado - YouTube
On my last race, I turned the controller up and left on more. Very happy with it
Funday Sunday in Mexico! - YouTube
