Kevhill85 2dr Tahoe porject ..
With he new frame the Tahoe body dropped 6 inch
My plans
1) 4link truck so I can keep back seat
2) install ls1 347 stroker / 4l60e
3) redone the to all black
4) remove all bags
5) make it more a prostreet truck
6) coil over the rear
7) install a 6lug 10bolt narrowed 3inch
8) whatever else I can think of
9) complete frame made of 2x4 1/4 wall . We added the rear clip to the new frame so I can still run a rear bumper .
10) set of 317 heads milled .040
More pic here
96 2dr Tahoe prostreet pictures by kevhill85 - Photobucket
Updated photo's right here
http://photobucket.com/albums/q169/k...ahoe prostreet
I took a few photos today. I hope to have this thing home this weekend.
Well the tahoe home and now the work can start!!!!
More pic here
My plans
4) remove all bags
More pic here
More pic here
Ok time for update and photos .. I hope to order the ls1 383 stroker kit next week..
New mounts /// Dirty Dingo
5.3 ls1 block borded out to a 3.905
New cam bearing install
Order a PSI wiring harness.. Very nice piece of work
All so bought a 3 inch narrowed rear end from a 2006 chevy truck
started to Install the 4 link
Schoenfeld headers
Schoenfeld headers
Today i mocked up the DRods fuel cell into my 2dr Tahoe .. I pick this cell from TxStVanWilder Friday and it fit great.. Here what left to do so the fuel cell fit the way I need to ..
Cut about 2 3/4 off the back side of the mounting tab
Add some rubber cushion between the frame and cell mounting tabs.. Should lowwer the cell about 3/4 of an inch
Ok finally had time to work on the Tahoe .
Cut the floor and made room for the drive shaft
Drilled and tapped the the head for a mech temp gauge.
You see in the next two photo how much the rear was narrowed .
This summer if e erything will go right..
Thing still needed
Coil over kit
F body assy
Sheet metal for floor
Braker lines
Fuel lines
Fuel pump..
I have to figure out if I want to go with 4160 tb and edle intake or ls6 intake
Thing still needed
Coil over kit
F body assy
Braker lines
Fuel lines
Fuel pump..
