Help Measurements & weight Needed for Project
Old Nov 14, 2016 | 07:47 AM
UV231 Project's Avatar
Default Help Measurements & weight Needed for Project
Hello Everyone,
I am having a hard time finding a reliable source for measurements and weight for the engine I plan to install in my project.
NOTE: I keep finding marine engine dimensions and specs. However, those engines are completely different.
They are much bigger and heavier than the all aluminum truck engine of the same liter.
I am looking for measurements and how much a 2014up LV3 4.3lt weighs.
I will keep searching and trying to find it too.
Any help would be greatly appreciated.
Thank you,
Old Nov 14, 2016 | 08:44 AM
Installing one of these:
Plan to install this in my UV231 Project.
In one of these:
My UV231 Project.
Old Nov 14, 2016 | 11:57 AM
BigKID's Avatar
Not sure of the difference between the LV3 and current LV1 but this may help...
4.3L LV1 V-6 Aluminum-Block Engine
Old Nov 14, 2016 | 12:07 PM
Thank you. The LV3 is an all new design like the newer 5.3L and 6.2L ecotec3 engines.
But I must say the picture makes it seem that they are the same.
Here are some specs that I found. But still no luck on measurements and weight.
2014 Ecotec3 - 4.3L - 5.3L and 6.2L Engine Specs.
Old Nov 14, 2016 | 03:32 PM
I am still looking for this info.. If anyone knows where to find it.
BTW - The link BigKid was kind enough to share does not have the weight and the measurement is not a true one - from bell housing mounting surface to farthest point forward. I could guess the difference - but I rather know for sure.
Thank you,
